M.2 -> PCI-express -> PCI-32bit
Discussion in 'UDOO X86' started by diglo, Jun 12, 2018.
  1. diglo
    diglo New Member
    Apr 29, 2017
    16
    Hello everyone, I just want to share my hack to use the Udoo x86 as a video processing device with legacy hardware.
    With a small saw and a cutter, I notched the B-key on a M-key riser off eBay, then I was able to tap into one PCI-express lane of the udoo and use a PCI-express to PCI-32bit adapter and finally connect a legacy 4 channel composite video grabber (Adlink PCI-RTV24) and use it with OpenCV under Win10.
    Everything works! :)
    M.2 riser:
    https://www.ebay.it/itm/NGFF-M-2-To...e=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
    TOP side:
    Bottom side:
    This small board exposes on PCIe lane with an USB connector
    The blue board is a SSD.
    Final result (sketchy AF):
  2. yankneck696
    yankneck696 New Member
    Dec 3, 2014
    23
    I thought that there were 2 lanes. I'll have to look again. If you have it working, could you post comparitive rspeed results, compared to another full tilt PC? I have been pondering an outboard video card for numerical processing (Software Defined Radio).
    Thank you,
    Ed
  3. ccs_hello
    494
    174
    That NGFF type-B slot has 2 PCIe 2.0 lanes.
  4. ccs_hello
    494
    174
    The eBay link M.2 riser board only has 1-lane PCIe possibility due the fact that it only uses one USB connector as the bus extension method.
