M4 gpio jitter
Discussion in 'UDOO NEO' started by sgygax, Sep 28, 2016.
Tags:
  1. sgygax
    sgygax New Member
    Jul 22, 2016
    Hi
    For driving some micro valves I need to generate pulses (no pwm!) with bitbanging.
    With the oscilloscope I see the pulsewidth with 500ns jitter.
    This is the test sketch:
    #include <mqx.h>
    void setup() {
      pinMode(13, OUTPUT);
    void loop() {
      while(1){
       _int_disable();
       digitalWrite(13, HIGH);
       digitalWrite(13, LOW);
       _int_enable();
       delay(10);
    Can anyone explain the jitter? Is there a solution to stop the jitter?
    Best regards
    Stefan
    First I am not an expert and did not use this yet. Using digitalwrite is not bit banging http://www.crash-bang.com/arduino-digital-io/
    So if the signal quality is this important you could investigate the arduino libraries on your Udoo and do real but banging by optimizing your code and don't use digitalwrite.
  3. sgygax
    sgygax New Member
    Jul 22, 2016
    Thanks for the answer! Below the new sketch. The output is faster put still has 400ns jitter.
    #include <mqx.h>
    void setup() {
      GPIO4_GDIR|=(1U<<6); //pinMode(13, OUTPUT);
    void loop() {
      while(1){
        _int_disable();
        GPIO4_DR|=(1U<<6);    //digitalWrite(13, HIGH);
        GPIO4_DR&=(~(1U<<6)); //digitalWrite(13, LOW);
        _int_enable();
        delay(10);
    My applications normaly runs on a arm M4 mcu (Atmle, ST) without jitter.
  4. waltervl
    I am out of options......someone else? @jas-mx ?
  5. sgygax
    sgygax New Member
    Jul 22, 2016
    IMG_1070.JPG This is how the output signals looks like...
  6. tcmichals
    tcmichals Member
    Feb 25, 2015
    54
    27
    Remove the delay call and use a hard loop inside disable interrupts. This way no RTOS task switching will occur or ISR processing.
  7. sgygax
    sgygax New Member
    Jul 22, 2016
    I disable interrupt to do my output for a defined time...
  8. tcmichals
    tcmichals Member
    Feb 25, 2015
    54
    27
    Current Code:
    void loop() {
    while(1){
    _int_disable();
    _int_enable(); <-- enable interrupts
    delay(10); <-- delay, RTOS is running
    New Code:
    void _hw_delay(uint32_t delay)
    //poll a timer
    void loop() {
    _int_disable();
    while(1){
    _hw_delay(10);
    _int_disable();
  9. sgygax
    sgygax New Member
    Jul 22, 2016
    Thank you for the code...
    My delay() can be unstable, I don't care about that.
    What I'm pointig out is the time between _int_disbale() and _int_enable(). This time is not always the same (jitter)!
    See my oscilloscope picture...
  10. sgygax
    sgygax New Member
    Jul 22, 2016
    If we solve this "udoo neo" comes par with Beaglebone concerning Realtime...
  11. tcmichals
    tcmichals Member
    Feb 25, 2015
    54
    27
    Might be an issue with using DDR for instructions, maybe load the code into I-TCM and execute, see if the timing changes.
  12. sgygax
    sgygax New Member
    Jul 22, 2016
    Thank you! Good idea, is it possibel to do that in a sketch?
  13. jas-mx
    jas-mx Active Member
    Dec 31, 2013
    407
    118
    You should try toggling the gpio pin from within inside an interrupt handler eg the epit would be a good option (not from a sketch). If you still see the jitter then you may need to review the IOMUX configuration (output characteristics) of the pin to see if you can reduced the switching noise.
  14. tcmichals
    tcmichals Member
    Feb 25, 2015
    54
    27
    Yes looking at the code _int_disable:
    The _int_disable() function disables all hardware interrupts at priorities up to and including the MQX disable-interrupt level
    So, there can be other interrupts still active. Could do a:
    #define _ENABLE_ISR(x) __asm volatile ("cpsie i")
    #define _DISABLE_ISR(x) __asm volatile ("cpsid i")
    For testing only
  15. sgygax
    sgygax New Member
    Jul 22, 2016
    Thank you, I've already tried this. It's still the same.
  16. sgygax
    sgygax New Member
    Jul 22, 2016
    See the sketch with IOMUX configuration:
    #include <mqx.h>
    void setup() {
      // iomuxc
      #define GPIO4_SPEED (3U<<6) /* 0..3 = 50mhz, 100mhz, 100mhz, 150mhz */
      #define GPIO4_DSE   (7U<<3) /* 0..7 = hiz, 260r, 130r, 88r, 65r, 52r, 43r, 37r */
      #define GPIO4_SRE   (1U<<0) /* 0..1 = slow, fast */
      IOMUXC_SW_PAD_CTL_PAD_NAND_DATA02=GPIO4_SPEED|GPIO4_DSE|GPIO4_SRE;
    void loop() {
      // put your main code here, to run repeatedly:
      while(1){
        _int_disable();
        GPIO4_DR|=(1U<<6);
        _int_enable();
        delay(10);
    I've also tried sketch with an interrupt handler and it was the same too.
    What do you mean by "not from a sketch"?
  17. sgygax
    sgygax New Member
    Jul 22, 2016
    It's now running from I-TCM and still the same...
  18. sgygax
    sgygax New Member
    Jul 22, 2016
    When I disable the timer GPT I have no more output jitter!
    But Linux does not work any more.
    GPT_CR&=(~(1U<<0));
    Any comments on this?
  19. jas-mx
    Dec 31, 2013
    407
    118
    The kernel is probably using the GPT internally, so disabling it isn't a good idea. You should launch your m4 code from uboot without starting the kernel to verify the linux side is affecting it.
  20. Andrea Rovai
    Hi there everybody,
    we've run the sketch and honestly we don't experience the problem.
    We've registered an impulse of about 250ns using the registers directly and an impulse of about 500ns using digitalwrite.
    This is the sketch we've used:
    void setup() {
    void loop() {
    while(1){
    _int_disable();
    // ton = 272 nsec
    // ton = 900 nsec
    _int_enable();
    delay(10);
    The timing has been measured with the help of an oscilloscope.
