Hi all, I like to share a link with you. We created an universal bundler to setup meterojs on UDOO. Very easy. Tom https://github.com/4commerce-technologies-AG/meteor
Hello Tom, Thanks for your effort! However I need help to install it. I followed your instructions on my UDOO but still I don't have a working installation. I have installed version 0.10.22 of node. I installed the following packages first: autotools-dev scons mongodb curl Then I cloned the repository and ran the script: ./scripts/generate-dev-bundle.sh It ended with a lot of warnings about missing dependencies like these: make: Entering directory `/tmp/generate-dev-bundle-Hm9VpD4y/lib/node_modules/meteor-pathwatcher-tweaks/build' CXX(target) Release/obj.target/pathwatcher/src/main.o CXX(target) Release/obj.target/pathwatcher/src/common.o CXX(target) Release/obj.target/pathwatcher/src/handle_map.o CXX(target) Release/obj.target/pathwatcher/src/pathwatcher_linux.o SOLINK_MODULE(target) Release/obj.target/pathwatcher.node SOLINK_MODULE(target) Release/obj.target/pathwatcher.node: Finished COPY Release/pathwatcher.node make: Leaving directory `/tmp/generate-dev-bundle-Hm9VpD4y/lib/node_modules/meteor-pathwatcher-tweaks/build' npm WARN unmet dependency /tmp/generate-dev-bundle-Hm9VpD4y/lib/node_modules/cordova requires nopt@'~2' but will load npm WARN unmet dependency /tmp/generate-dev-bundle-Hm9VpD4y/lib/node_modules/nopt, npm WARN unmet dependency which is version 3.0.1 npm WARN unmet dependency /tmp/generate-dev-bundle-Hm9VpD4y/lib/node_modules/cordova requires underscore@'1.4.4' but will load Can you provide some advise?
The message I get when trying to run ./meteor --help: ubuntu@udoobuntu: ~/meteorjs/meteor $ ./meteor --help It's the first time you've run Meteor from a git checkout. I will download a kit containing all of Meteor's dependencies. ######################################################################## 100.0% gzip: stdin: not in gzip format tar: Child returned status 1 tar: Error is not recoverable: exiting now Failed to install dependency kit.
