minimize sleep power consumption for solar powered system
Discussion in 'General Discussion' started by spinxz, May 4, 2015.
  1. spinxz
    spinxz New Member
    Dec 26, 2013
    I am trying to build a sensor/meteorological station with the Udoo. However, the system will have to run "in the wild" on a battery which is charged with a solar panel. The station transmits sensor data via a 4G modem.
    The Udoo (quad) uses approx. 450mA when running without peripherals. This is far too much for my solar/battery powered system. Instead, I just wake up the Udoo every hour to read out the sensor data and transmit them to a webserver.
    So my question is what is the best way to put the Udoo to sleep for a certain interval and wake it up again.
    I tested
    rtcwake -m mem -s 60
    i.e. suspend to ram, off and disk mode are not supported. With rtcwake -m mem I managed to cut the power consumption to 85mA. In contrast, when the Udoo is turned off, the system/voltage regulator still consumes about 33mA.
    Ideally, I would like to get below 15mA but even less then 40mA would help me.
    Of course some external clock/timer could be used to cut the power but I would like to avoid that.
    1) Is there a better way than rtcwake -m mem to put Udoo to sleep for a certain time with respect to power consumption?
    2) Could the Arduino be used somehow?
    3) What exactly is the battery connector J25 good for? Could I use it to connect a more efficient voltage regulator?
    4) What is the required voltage range on the J25 battery connector?
    Thanks!
  2. vpeter
    vpeter Active Member
    Nov 29, 2014
    303
    62
  3. MrSeanMan
    MrSeanMan New Member
    Dec 14, 2017
