Multiple power sources
Discussion in 'UDOO BOLT' started by gl0p, Mar 28, 2022.
  1. gl0p
    gl0p UDOOer
    Mar 26, 2022
    Is there any setting in bios or otherwise that can allow two power sources to be connected at any time. Id like to have it connected with DC power jack and or one usb-c power source. Or two usb-c power sources.
    I am working on a robotics project and would like to basically connect one power suply while the other is connected, then disconnect the originally pluggen in power source without the bolt shutting down.
    It would be nice to have a function to block out or delete the power output on usb-c and keep it in PD mode if desired. Eventually id like to swap between two usb-c battery packs without interuption.
