Hello, I was following a tutorial which said to remove the occasional terminal errors from usb/serial you should type "setenv" to so that it will set the correct baud etc. Well I did that, and now the Udoo won't boot by itself anymore. I do have access to Uboot shell, and figured out how to manually start and stop kernels. However, all the original settings and autoboot function is missing for all distros now, regardless of what's on the SD Card. Can someone help me out and post a working uboot config for the Udoo Dual that I might be able to flash it back to stock settings? Thank you.
