Hi folks, i'm in despair. I've tried a lot of different distros: Linaro Ubuntu 12.04 LTS, Linaro Ubuntu 11.10 and Android 4.2.2 Jelly Bean. Also changing my HDMI-cabels, one of this is the udoo starterkit cable. But nothing is happend. I've Tried also to used the vt1613, but without positive results. Has some one else this kind of problem? The Linaro Ubuntu dmsg out looks good. Code: root@udoo:~# cat /etc/issue Ubuntu 12.04 LTS \n \l root@udoo:~# cat /var/log/dmesg .805344] hw-breakpoint: found 6 breakpoint and 1 watchpoint registers. [ 0.812179] hw-breakpoint: 1 breakpoint(s) reserved for watchpoint single-step. [ 0.819539] hw-breakpoint: maximum watchpoint size is 4 bytes. [ 0.825426] L310 cache controller enabled [ 0.829468] l2x0: 16 ways, CACHE_ID 0x410000c7, AUX_CTRL 0x02070000, Cache size: 1048576 B [ 0.864518] bio: create slab <bio-0> at 0 [ 0.872406] mxs-dma mxs-dma-apbh: initialized [ 0.877087] print_constraints: vmmc: 3300 mV [ 0.882160] vgaarb: loaded [ 0.885693] SCSI subsystem initialized [ 0.889831] libata version 3.00 loaded. [ 0.890582] usbcore: registered new interface driver usbfs [ 0.896208] usbcore: registered new interface driver hub [ 0.901707] usbcore: registered new device driver usb [ 0.906776] Freescale USB OTG Driver loaded, $Revision: 1.55 $ [ 0.928792] imx-ipuv3 imx-ipuv3.0: IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F(6,7) [ 0.948786] imx-ipuv3 imx-ipuv3.1: IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F(6,7) [ 0.956618] mxc_mipi_csi2 mxc_mipi_csi2: i.MX MIPI CSI2 driver probed [ 0.963096] mxc_mipi_csi2 mxc_mipi_csi2: i.MX MIPI CSI2 dphy version is 0x3130302a [ 0.970813] MIPI CSI2 driver module loaded [ 0.975138] Advanced Linux Sound Architecture Driver Version 1.0.24. [ 0.982292] Bluetooth: Core ver 2.16 [ 0.985994] NET: Registered protocol family 31 [ 0.990461] Bluetooth: HCI device and connection manager initialized [ 0.996837] Bluetooth: HCI socket layer initialized [ 1.001736] Bluetooth: L2CAP socket layer initialized [ 1.006877] Bluetooth: SCO socket layer initialized [ 1.012226] cfg80211: Calling CRDA to update world regulatory domain [ 1.019672] i2c-core: driver [max17135] using legacy suspend method [ 1.025960] i2c-core: driver [max17135] using legacy resume method [ 1.032188] Switching to clocksource mxc_timer1 [ 1.051712] NET: Registered protocol family 2 [ 1.056267] IP route cache hash table entries: 32768 (order: 5, 131072 bytes) [ 1.064197] TCP established hash table entries: 131072 (order: 8, 1048576 bytes) [ 1.073539] TCP bind hash table entries: 65536 (order: 7, 786432 bytes) [ 1.081280] TCP: Hash tables configured (established 131072 bind 65536) [ 1.087931] TCP reno registered [ 1.091091] UDP hash table entries: 512 (order: 2, 16384 bytes) [ 1.097076] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes) [ 1.103796] NET: Registered protocol family 1 [ 1.108480] RPC: Registered named UNIX socket transport module. [ 1.114421] RPC: Registered udp transport module. [ 1.119161] RPC: Registered tcp transport module. [ 1.123880] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 1.130358] PCI: CLS 0 bytes, default 32 [ 1.131229] PMU: registered new PMU device of type 0 [ 1.136333] Static Power Management for Freescale i.MX6 [ 1.141598] wait mode is enabled for i.MX6 [ 1.145890] cpaddr = c0880000 suspend_iram_base=c08fc000 [ 1.151320] PM driver module loaded [ 1.155207] IMX usb wakeup probe [ 1.158566] the wakeup pdata is 0xbfc18080 [ 1.158960] add wake up source irq 75 [ 1.166229] IMX usb wakeup probe [ 1.169565] the wakeup pdata is 0xbf9fd280 [ 1.169756] cpu regulator mode:ldo_enable [ 1.173974] i.MXC CPU frequency driver [ 1.204062] JFFS2 version 2.2. (NAND) \xffffffc2\xffffffa9 2001-2006 Red Hat, Inc. [ 1.210967] msgmni has been set to 1750 [ 1.216347] alg: No test for stdrng (krng) [ 1.220626] io scheduler noop registered [ 1.224562] io scheduler deadline registered [ 1.228948] io scheduler cfq registered (default) [ 1.234749] MIPI DSI driver module loaded [ 1.238975] mxc_sdc_fb mxc_sdc_fb.0: register mxc display driver hdmi [ 1.245473] mxc_hdmi mxc_hdmi: Detected HDMI controller 0x13:0xa:0xa0:0xc1 [ 1.252398] fbcvt: 1920x1080@60: CVT Name - 2.073M9 [ 1.257312] fb_videomode = 59 1920 1080 5780 328 128 3 32 200 5 2 0 32 [ 1.276248] imx-ipuv3 imx-ipuv3.0: WARNING: adapt panel end blank lines [ 1.286838] imx-ipuv3 imx-ipuv3.0: IPU DMFC DP HIGH RESOLUTION: 1(0,1), 5B(2~5), 5F(6,7) [ 1.320147] imx-ipuv3 imx-ipuv3.0: WARNING: adapt panel end blank lines [ 1.353526] Console: switching to colour frame buffer device 160x64 [ 1.401664] mxc_sdc_fb mxc_sdc_fb.1: register mxc display driver ldb [ 1.408081] _regulator_get: get() with no identifier [ 1.420771] mxc_sdc_fb mxc_sdc_fb.2: register mxc display driver ldb [ 1.431936] fbcvt: 1920x1080@60: CVT Name - 2.073M9 [ 1.436857] fb_videomode = 59 1920 1080 5780 328 128 3 32 200 5 2 0 32 [ 1.444639] imx-sdma imx-sdma: loaded firmware 1.1 [ 1.448923] imx-sdma imx-sdma: initialized [ 1.537381] fb_videomode = 59 640 480 39721 48 16 33 10 96 2 0 16 32 [ 1.571876] fb_videomode = 59 1360 768 11799 208 72 22 3 136 5 1 0 17 [ 1.608861] Serial: IMX driver [ 1.608974] imx-uart.0: ttymxc0 at MMIO 0x2020000 (irq = 58) is a IMX [ 1.609382] imx-uart.1: ttymxc1 at MMIO 0x21e8000 (irq = 59) is a IMX [ 1.677438] fb_videomode = 59 1360 768 11799 208 72 22 3 136 5 1 0 32 [ 1.677454] fb_videomode = 59 1360 768 11799 208 72 22 3 136 5 1 0 17 [ 1.722302] console [ttymxc1] enabled, bootconsole disabled [ 1.734126] imx-uart.3: ttymxc3 at MMIO 0x21f0000 (irq = 61) is a IMX [ 1.746083] loop: module loaded [ 1.749626] request BOSSA_CLK IRQ [ 1.752945] registering IRQ 419 for BOSSAC Arduino erase/reset operation [ 1.802709] No sata disk. [ 1.806564] GPMI NAND driver registered. (IMX) [ 1.811936] vcan: Virtual CAN interface driver [ 1.816387] CAN device driver interface [ 1.820233] flexcan netdevice driver [ 1.823972] FEC Ethernet Driver [ 1.829293] fec_enet_mii_bus: probed [ 1.837749] usbcore: registered new interface driver rt2800usb [ 1.843586] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 1.850258] fsl-ehci fsl-ehci.0: Freescale On-Chip EHCI Host Controller [ 1.856904] fsl-ehci fsl-ehci.0: new USB bus registered, assigned bus number 1 [ 1.886792] fsl-ehci fsl-ehci.0: irq 75, io base 0x02184000 [ 1.906786] fsl-ehci fsl-ehci.0: USB 2.0 started, EHCI 1.00 [ 1.913026] hub 1-0:1.0: USB hub found [ 1.916805] hub 1-0:1.0: 1 port detected [ 1.920904] add wake up source irq 72 [ 1.924602] fsl-ehci fsl-ehci.1: Freescale On-Chip EHCI Host Controller [ 1.931276] fsl-ehci fsl-ehci.1: new USB bus registered, assigned bus number 2 [ 1.976783] fsl-ehci fsl-ehci.1: irq 72, io base 0x02184200 [ 2.006776] fsl-ehci fsl-ehci.1: USB 2.0 started, EHCI 1.00 [ 2.012946] hub 2-0:1.0: USB hub found [ 2.016709] hub 2-0:1.0: 1 port detected [ 2.021001] Initializing USB Mass Storage driver... [ 2.026046] usbcore: registered new interface driver usb-storage [ 2.032095] USB Mass Storage support registered. [ 2.037001] usbcore: registered new interface driver usbserial [ 2.042933] USB Serial support registered for generic [ 2.048118] usbcore: registered new interface driver usbserial_generic [ 2.054648] usbserial: USB Serial Driver core [ 2.059118] USB Serial support registered for debug [ 2.064111] usbcore: registered new interface driver debug [ 2.069613] ARC USBOTG Device Controller driver (1 August 2005) [ 2.075880] g_ether gadget: using random self ethernet address [ 2.081741] g_ether gadget: using random host ethernet address [ 2.088313] usb0: MAC 6a:68:94:90:1a:26 [ 2.092151] usb0: HOST MAC 22:d5:ff:a7:84:c4 [ 2.096428] g_ether gadget: controller 'fsl-usb2-udc' not recognized; trying CDC Ethernet (ECM) [ 2.105165] g_ether gadget: Ethernet Gadget, version: Memorial Day 2008 [ 2.111799] g_ether gadget: g_ether ready [ 2.115813] Suspend udc for OTG auto detect [ 2.120017] USB Host suspend begins [ 2.120023] will suspend roothub and its children [ 2.120042] ehci_fsl_bus_suspend begins, DR [ 2.120120] ehci_fsl_bus_suspend ends, DR [ 2.120134] host suspend ends [ 2.120141] USB Gadget resume begins [ 2.120146] fsl_udc_resume, Wait for wakeup thread finishes [ 2.146783] dr_controller_run: udc out low power mode [ 2.146792] USB Gadget resume ends [ 2.146799] fsl-usb2-udc: bind to driver g_ether [ 2.152022] mousedev: PS/2 mouse device common for all mice [ 2.158000] usbcore: registered new interface driver usbtouchscreen [ 2.164677] Sitronix touch driver 2.9.1 [ 2.168529] Release date: 20120507 [ 2.172282] sitronix_reset_ic [ 2.295503] send status reg command error (-5) [ 2.299973] sitronix: probe of 2-0055 failed with error -5 [ 2.305892] i2c-core: driver [isl29023] using legacy suspend method [ 2.312177] i2c-core: driver [isl29023] using legacy resume method [ 2.319041] snvs_rtc snvs_rtc.0: rtc core: registered snvs_rtc as rtc0 [ 2.325714] i2c /dev entries driver [ 2.330017] Linux video capture interface: v2.00 [ 2.356799] usb 2-1: new high speed USB device number 2 using fsl-ehci [ 2.456876] ov5640_read_reg:write reg error:reg=300a [ 2.461842] camera ov5640_mipi is not found [ 2.466433] mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video16 [ 2.474070] mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video17 [ 2.481706] mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video18 [ 2.489367] mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video19 [ 2.497010] mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video20 [ 2.504783] vivi-000: V4L2 device registered as video2 [ 2.509942] Video Technology Magazine Virtual Video Capture Board ver 0.8.0 successfully loaded. [ 2.519128] usbcore: registered new interface driver uvcvideo [ 2.524914] USB Video Class driver (v1.1.0) [ 2.529848] i2c-core: driver [mag3110] using legacy suspend method [ 2.536055] hub 2-1:1.0: USB hub found [ 2.539836] i2c-core: driver [mag3110] using legacy resume method [ 2.545954] hub 2-1:1.0: 4 ports detected [ 2.550602] imx2-wdt imx2-wdt.0: IMX2+ Watchdog Timer enabled. timeout=60s (nowayout=1) [ 2.558759] Bluetooth: Virtual HCI driver ver 1.3 [ 2.563779] Bluetooth: HCI UART driver ver 2.2 [ 2.568240] Bluetooth: HCIATH3K protocol initialized [ 2.573206] Bluetooth: Generic Bluetooth USB driver ver 0.6 [ 2.578934] usbcore: registered new interface driver btusb [ 2.584572] sdhci: Secure Digital Host Controller Interface driver [ 2.590767] sdhci: Copyright(c) Pierre Ossman [ 2.595442] mmc0: SDHCI controller on platform [sdhci-esdhc-imx.2] using DMA [ 2.602782] mxc_vdoa mxc_vdoa: i.MX Video Data Order Adapter(VDOA) driver probed [ 2.613999] VPU initialized [ 2.617335] mxc_asrc registered [ 2.642184] Thermal calibration data is 0x5864f169 [ 2.646996] Thermal sensor with ratio = 183 [ 2.666783] Anatop Thermal registered as thermal_zone0 [ 2.672084] anatop_thermal_probe: default cooling device is cpufreq! [ 2.681080] usbcore: registered new interface driver usbhid [ 2.686659] usbhid: USB HID core driver [ 2.690961] usbcore: registered new interface driver snd-usb-audio [ 2.697705] mxc_hdmi_soc mxc_hdmi_soc.0: MXC HDMI Audio [ 2.703156] Cirrus Logic CS42888 ALSA SoC Codec Driver [ 2.708409] i2c-core: driver [cs42888] using legacy suspend method [ 2.714603] i2c-core: driver [cs42888] using legacy resume method [ 2.744068] mmc0: new high speed SDHC card at address aaaa [ 2.749931] mmcblk0: mmc0:aaaa SU08G 7.40 GiB [ 2.759290] mmcblk0: p1 [ 2.803194] audio_codec_ac97_cold_reset [ 2.856946] USB Gadget resume begins [ 2.856954] fsl_udc_resume, Wait for wakeup thread finishes [ 2.857254] usb 2-1.1: new low speed USB device number 3 using fsl-ehci [ 2.889362] Found Audio codec AC97 vt1613, [ID = 5649 - 4123] [ 2.907583] asoc: vt1613 <-> imx-ssi.0 mapping ok [ 2.913889] imx_3stack asoc driver [ 2.918852] asoc: mxc-hdmi-soc <-> imx-hdmi-soc-dai.0 mapping ok [ 2.925519] ALSA device list: [ 2.928499] #0: vt1613-audio [ 2.931554] #1: imx-hdmi-soc [ 2.934810] NET: Registered protocol family 26 [ 2.939808] TCP cubic registered [ 2.943039] NET: Registered protocol family 17 [ 2.947505] can: controller area network core (rev 20090105 abi 8) [ 2.953765] NET: Registered protocol family 29 [ 2.958222] can: raw protocol (rev 20090105) [ 2.962494] can: broadcast manager protocol (rev 20090105 t) [ 2.968237] Bluetooth: RFCOMM TTY layer initialized [ 2.973122] Bluetooth: RFCOMM socket layer initialized [ 2.978326] Bluetooth: RFCOMM ver 1.11 [ 2.982078] Bluetooth: BNEP (Ethernet Emulation) ver 1.3 [ 2.987400] Bluetooth: BNEP filters: protocol multicast [ 2.992627] Bluetooth: HIDP (Human Interface Emulation) ver 1.2 [ 2.998738] lib80211: common routines for IEEE802.11 drivers [ 3.004433] lib80211_crypt: registered algorithm 'NULL' [ 3.004441] lib80211_crypt: registered algorithm 'WEP' [ 3.004447] lib80211_crypt: registered algorithm 'CCMP' [ 3.004466] lib80211_crypt: registered algorithm 'TKIP' [ 3.004480] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4 [ 3.012564] Bus freq driver module loaded [ 3.016618] Bus freq driver Enabled [ 3.020146] input: Logitech USB-PS/2 Optical Mouse as /devices/platform/fsl-ehci.1/usb2/2-1/2-1.1/2-1.1:1.0/input/input0 [ 3.021930] mxc_dvfs_core_probe [ 3.022134] DVFS driver module loaded [ 3.037827] snvs_rtc snvs_rtc.0: setting system clock to 1970-01-01 00:00:01 UTC (1) [ 3.046226] generic-usb 0003:046D:C050.0001: input,hidraw0: USB HID v1.10 Mouse [Logitech USB-PS/2 Optical Mouse] on usb-fsl-ehci.1-1.1/input0 [ 3.054737] EXT3-fs: barriers not enabled [ 3.147939] usb 2-1.2: new low speed USB device number 4 using fsl-ehci [ 3.297671] input: USB Keyboard as /devices/platform/fsl-ehci.1/usb2/2-1/2-1.2/2-1.2:1.0/input/input1 [ 3.308172] generic-usb 0003:04D9:1702.0002: input,hidraw1: USB HID v1.10 Keyboard [ USB Keyboard] on usb-fsl-ehci.1-1.2/input0 [ 3.337543] input: USB Keyboard as /devices/platform/fsl-ehci.1/usb2/2-1/2-1.2/2-1.2:1.1/input/input2 [ 3.348319] generic-usb 0003:04D9:1702.0003: input,hidraw2: USB HID v1.10 Device [ USB Keyboard] on usb-fsl-ehci.1-1.2/input1 [ 3.437080] usb 2-1.3: new high speed USB device number 5 using fsl-ehci [ 3.603228] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht' [ 3.604947] Registered led device: rt2800usb-phy0::radio [ 3.605076] Registered led device: rt2800usb-phy0::assoc [ 3.605203] Registered led device: rt2800usb-phy0::quality [ 17.203669] kjournald starting. Commit interval 5 seconds [ 17.207587] EXT3-fs (mmcblk0p1): using internal journal [ 17.207595] EXT3-fs (mmcblk0p1): recovery complete [ 17.210368] EXT3-fs (mmcblk0p1): mounted filesystem with writeback data mode [ 17.210405] VFS: Mounted root (ext3 filesystem) on device 179:1. [ 17.214453] devtmpfs: mounted [ 17.214509] Freeing init memory: 196K [ 17.626930] init: ureadahead main process (1546) terminated with status 5 [ 20.225972] udevd[1654]: starting version 175 [ 20.897378] udevd[2616]: renamed network interface eth0 to eth4 [ 21.847698] udevd[2697]: renamed network interface wlan0 to wlan4 [ 22.200870] ERROR: v4l2 capture: slave not found! [ 22.205660] ERROR: v4l2 capture: slave not found! [ 22.690147] init: failsafe main process (3126) killed by TERM signal [ 23.222188] eth4: Freescale FEC PHY driver [Generic PHY] (mii_bus:phy_addr=1:06, irq=-1) [ 23.222232] Activating ethernet physical layer Micrel KSZ9031 Gigabit PHY.
