No Link With Crossover Cable?
Discussion in 'UDOO NEO' started by ctassell, Jul 19, 2019.
Tags:
  1. ctassell
    ctassell UDOOer
    Apr 9, 2015
    19
    Hi Everyone,
    I have a strange one here. I have two Udoo Neo's connected with a crossover Ethernet cable and I'm getting no carrier on eth0. If I plug those same two Neo's into a switch, with the same configuration, they work fine. I'm running Debian on the Neo's, but this shouldn't be a software issue. Is there something funny about the Udoo Ethernet chip that it doesn't like direct cabling?
    I suppose this is because there is no IP address assigned when you use 2 Neo's connected to each other. When connected to the router they will get an IP address from the router.
    You will have to modify the file /etc/network/interfaces on both Udoo Neo's so they will get an unique static IP, each within the range of your router (for future connections).
    There is enough information onliner how to set static IP on the Udoo Neo.
    You could start with this https://www.udoo.org/forum/threads/tutorial-newbie-how-to-set-static-ip-in-ubuntu.651/
  3. ctassell
    ctassell UDOOer
    Apr 9, 2015
    19
    No, it's not a software issue (at least not a simple one.) I have assigned static IPs to the Neo's and plugged them into a switch and they work fine. But when I use a crossover cable (I've tried with 2 different cables and put one of them through a cable tester) I get "NO CARRIER" with "ip addr show dev eth0" I've confirmed that the IPs are still there on both Udoos, I've run "ip link up" but that doesn't make a difference. There seems to be some issue that the Neo won't recognize an Ethernet connection unless there is some sort of signalling from the other end that the Neo itself won't provide.
  4. sirrab
    sirrab UDOOer
    Jul 26, 2014
    263
    32
    Perhaps a "straight" thru Ethernet cable will work.
  5. ctassell
    ctassell UDOOer
    Apr 9, 2015
    19
    Yeah, I tried a straight through Ethernet cable originally and thought it was odd that it didn't work (haven't seen an Ethernet device that didn't have auto-MDIX in years) so that's why I tried the crossover. I have even tried this with two different pairs of Neo's and no luck, so it's something about the hardware. I'm wondering if it's a power thing (neither Udoo being willing the first to send current) or just some sort of unimplemented handshake feature that is messing it up.
