No Space
Discussion in 'General Discussion' started by Elenilson, Jun 14, 2020.
  1. Elenilson
    Elenilson New Member
    Jun 14, 2020
    ood night, I use the Proxmox VE in a laboratory for studies.
    I have 2 discs:
    * 1 SATA 6GBps 7200RPM 1TB HD
    * 1 6GB SATA 480GB SSD
    - HD is used only for software and files
    - The SSD I use only for the VM's systems
    The HD is 100% busy and that's correct because I have allocated it all to a single disk
    I needed space on the SSD for a new VM so exclude a VM that I no longer used.
    Look at the problem, the space didn't come back despite having deleted the VM. How do I clean data from previous VM's?
    Before the update there was no PURGE option when trying to delete a VM, is this option related?
    Thank you very much, I count on your help.
  2. Parker Chyna
    Parker Chyna New Member
    Dec 30, 2021
    We saved big buying a used iphone 6Splus then getting the Sim card from Cricket only to find out there's a law, if you don't buy your phone from your carrier, they cannot provide you with WI-FI calling. I can connect to WI-FI internet, but not calling. Consequently, I miss lots of calls and texts. Now saving for a Cricket phone.
  3. CharlesS
    CharlesS UDOOer
    Nov 7, 2022
    Thanks for the info I will try to figure it out for more.
