OpenELEC 6.0.0
Discussion in 'XBMC' started by vpeter, Nov 3, 2015.
  1. vpeter
    vpeter Active Member
    Nov 29, 2014
    303
    62
  2. bigchrizzieboy
    bigchrizzieboy New Member
    Dec 1, 2014
    16
    vpeter likes this.
  3. mmeinert
    mmeinert Member
    Jun 17, 2014
    61
    Big thank you for your work !
    vpeter likes this.
  4. Viper780
    Viper780 New Member
    May 5, 2014
    19
    Many Thanks!
    are there any performance Tipps and Hints?
  5. ivan
    ivan Member
    Mar 8, 2015
    77
    Runs fantastic, Peter, thanks.
    Is it possible to connect a rtl/sdr usb on kodi?
  6. Andrea Rovai
    Peter, as I told you via private messages: great!!!
    vpeter likes this.
  7. ivan
    ivan Member
    Mar 8, 2015
    77
    For Peter
    [​IMG]
    vpeter likes this.
  8. DanMcGovern
    DanMcGovern New Member
    Nov 10, 2015
    This is my first post so be gentle.
    Is an external drive and/or TV tuner shield necessary for live TV streaming?
  9. ivan
    ivan Member
    Mar 8, 2015
    77
    You don't need an external drive.
    For streaming via internet, you dont need a tv dongle as well.
    vpeter likes this.
  10. Viper780
    Viper780 New Member
    May 5, 2014
    19
    @DanMcGovern
    From where do you want to stream? You can access also your Enigma Sat receiver or use one of the Internetportals
  11. jerrino77
    jerrino77 Member
    Nov 25, 2013
    30
    Hello vpeter, sorry but my udoo quad won't boot your image. It hags on "Starting kernel....." then boots up again. Have I to do something else than run the command "dd bs=1M if=/<image> of=<devname>? Thanks
  12. vpeter
    Nov 29, 2014
    303
    62
    Open file uEnv.txt on SD card and enable serial console.
    Comment this line
    console_arg=quiet morequiet
    and remove comment on this
    console_arg=console=ttymxc0,115200 no_console_suspend=1
    Then connect with putty or some other program and check what you get on console. You can copy/paste to web page http://pastebin.com/
  13. jerrino77
    jerrino77 Member
    Nov 25, 2013
    30
    Ok, did it, simply the system was up and running but i wait for login promp but there is not!! Hehehe.. Another question, i don't have an IR receiver connected so i have to use keyboard, but it does't work. Tips??
  14. jerrino77
    jerrino77 Member
    Nov 25, 2013
    30
    Ok, i've connected a mouse and it works for now. Well, now i want to see live tv from my USB DTT stick, have I to install VDR backend and what else?
  15. ivan
    ivan Member
    Mar 8, 2015
    77
    Let me show you my media center with Kodi 6 (thanks Peter)
    klik
    On the rghthand site you see a little amplifeier, a creddle for HDD and the UDO Quad.
    The tube are batteries fron a old laptop.
    I solved the wifi iddue with the help of this manual. klik
    Andrea Rovai and bigchrizzieboy like this.
  16. jerrino77
    jerrino77 Member
    Nov 25, 2013
    30
    I don't have issues with wifi. But i would like to watch live TV like my Enigma2 STB. Unfortunately, the vision is buggy, it seems a bad IPTV even with an USB DTT stick connected. I've used VDR because is the only one that have a "skinned" channel search system. TvHeadend could search channels only over PC browser. But works great as Mediacenter!!!
    PS. Sorry for my english
    Andrea Rovai likes this.
  17. Sandroelec
    Sandroelec New Member
    Feb 15, 2015
    15
    Hello everybody!
    Thank Vpeter for the new version of the program! It's very useful, i like so much!
    I would like to realize a graphical interface for the arduino 2 installed onboard. I've realized my program on processing. Can i install it on kodi? how i can convert the program to transform it in add-on compatible?Kodi can see the serial port that communicate to arduino?
    Thank a lot
    Sandro
  18. vpeter
    Nov 29, 2014
    303
    62
    I don't think current kernel version will work with arduino and sam3x.
  19. ivan
    ivan Member
    Mar 8, 2015
    77
    And separate
    Via a micro usb?
    With a tft/lcd screen....
    But I don't think so....
    Also the outt/input has the 3.3v limitation
  20. Sandroelec
    Feb 15, 2015
    15
    but the kernel know the serial port?
