OpenGL on UDOO
Discussion in 'General Programming Discussion' started by killkrt, Nov 9, 2013.
  1. killkrt
    killkrt New Member
    Nov 1, 2013
    22
    I was trying to build a simple OpenGL application using GLFW (http://www.glfw.org), but I got some problems that are reported in this thread https://sourceforge.net/p/glfw/discussion/247562/thread/6bca3e40/. Basically the problem is that if I compile without any special option the code compile, but then it crashes as it try to create a OpenGL context, while if I compile using the ES extensions I got some errors at compile time :cry:
    I got also problems running examples bundled with OpenKinect (http://openkinect.org/wiki/Main_Page) since they use OpenGL.
    So, are you able to build and run a simple OpenGL application? It would be great to get GLFW working since I think it's a great library and I'd like to use it in a project made with the UDOO!
    Thank you.
  2. DracoLlasa
    DracoLlasa UDOOer
    Oct 15, 2013
    419
    I dont know much about it personally but there are already a few OpenGL related threads, have you checked?
    This is probably the most active and accomplished
    viewtopic.php?f=14&t=273
    These are related to getting OpenGL Running properly, so it may not be exactly what your looking for but either way, hope it helps.
  3. killkrt
    killkrt New Member
    Nov 1, 2013
    22
    Thank you!
    I'll continue on the other thread!
