+= operator and Concat issues
Discussion in 'Arduino IDE' started by Ryan, Apr 14, 2014.
  1. Ryan
    Ryan New Member
    Dec 3, 2013
    There seems to be somewhat of an issue when i'm trying to add a char to a string. When this code uploads, nothing shows, but when using the Slave Receiver example, it reads what I want but without combining them together.
    My code is below.
    while(Wire.available())
        char c = Wire.read();
        result += c;  //adds the read character to string to build full reading info. E.g. "2-20"
      Serial.println(result); //prints result which is in turn picked up by control panel software
      result = ""; //reset string
    Any help would be greatly appreciated
    Ryan
  2. mkopack
    mkopack Member
    451
    Don't have access to my Udoo or arduino right now, but try this:
    Try casting the char to a string and using Concat:
    result.concat((String) c);
    That way you're appending a string to a string, rather than a char to a string.
    What sort of result are you seeing with the code you posted?
  3. Ryan
    Ryan New Member
    Dec 3, 2013
    Thanks for your reply.
    I tried using the += and concat functions, and nothing at all would show, and if i attempted to modify the sketch, to just add a print statement, nothing at all would show. It essentially broke the sketch. I'll get it tested on my udoo tomorrow morning.
    Thanks!
    P.S I wrote the code on an Uno originally, and worked perfectly.
