Orange LED ,UDOO x86 Advanced Plus
Discussion in 'UDOO X86' started by okgood, Dec 21, 2017.
  1. okgood
    okgood New Member
    Oct 10, 2017
    11
    [​IMG]
    after put power to UDOO board show orange LED , in normal case will show green LED
    so how can i do or fix it ?
    thank you
    Best Regards
  2. ccs_hello
    517
    188
    The board has power, however the CPU is in sleep/hibernation mode.
    ccs_hello
    LDighera likes this.
  3. goldio
    goldio New Member
    Apr 14, 2017
    10
    Had the problem just now....
    After you have de-energized the board, press the small black reset button in the upper right corner of your picture. Then go to the BIOS and reset all settings. After you have de-energized the board again, restore your original settings in the BIOS. After another restart you should be able to boot your board normally again.
    In this way I got my board back to boot correctly. Maybe there is another easier way, but I didn't find anything about it on the internet.
  4. Sjonno
    Sjonno New Member
    Apr 24, 2017
    The board boots when you press the small power button next to the orange LED (at the side of the board). My UDOO always has the orange LED when I power it down from Windows.
  5. okgood
    okgood New Member
    Oct 10, 2017
    11
    thank you for solution but after do this don't work
  6. okgood
    okgood New Member
    Oct 10, 2017
    11
    when i put the power UDOO board will show orange LED and not any thing happen
  7. waltervl
    2,306
    578
  8. waltervl
    2,306
    578
  9. okgood
    okgood New Member
    Oct 10, 2017
    11
    th
    thank you for solution , but don't show anything on monitor when i put cable power to UDOO board
  10. drc85
    drc85 Member
    Dec 30, 2017
    45
    had the same yesterday... just pluged the power off and back in and it worked..
  11. okgood
    okgood New Member
    Oct 10, 2017
    11
    thank you for solution but unlucky for me not work. T T
  12. waltervl
    2,306
    578
  13. Darknain
    Darknain New Member
    Mar 7, 2018
    24
    I am in the same situation, the led is orange and when I put a cable to a screen nothing happens, the screen stays black
  14. waltervl
    2,306
    578
    Try another cable and another monitor or TV. The UEFI output is a little bit picky in accepting monitors. Also use a normal keyboard, not a wireless one to press the ESC button (a lot!!)
  15. Salem Mansor
    Salem Mansor New Member
    Feb 10, 2019
    I have same problem.:(
    Is there anyone who has a solution to this problem?
    Thanks
  16. Paul Kuijten
    Paul Kuijten UDOOer
    Aug 31, 2020
    I've got the same problem. I just get the yellow light and can't turn it on. Is there a way to try to fix this?
  17. waltervl
    2,306
    578
    Is it a new board or did it run before? If it is new please go to the startup section of the documentation. If it is a running board it looks like it cannot boot anymore.
    Do you see Udoo logo at boot?
    Did you try another monitor and/or HDMI cable?
    Did you try to boot with a Ubuntu live USB?
  18. Paul Kuijten
    Paul Kuijten UDOOer
    Aug 31, 2020
    I've tried the Ubuntu Live USB but it just won't boot..
    No, i even can't see a boot logo, it just won't wake up from standby.
    I've had it boot up once some time ago, but the internal storage always worked very crappy, but now i have some more time.. i tried to spend some more time to fix it.. but now it just doesn't start up.. :(
  19. waltervl
    2,306
    578
