Power supply compatibility list
Discussion in 'UDOO BOLT' started by Flash2k6, Apr 17, 2019.
  1. Flash2k6
    Flash2k6 New Member
    Jun 14, 2018
    12
    huthamcau likes this.
  2. ccs_hello
    536
    194
    2 Meters USB-C to USB-C cable, 2 pack, $9
    https://www.amazon.com/gp/product/B07GZH2WTV
    Apple A1718 61W USB-C PD power supply (AMZ or eBay)
    AC to DC 19V 3.42A power adapter, search eBay 183301986663, about $11 shipped.
  3. Chad Ringstrom
    Chad Ringstrom New Member
    Apr 17, 2019
    16
    13
    Not the cheapest but was available same day I got my Bolt delivered, and as a bonus you get other tips for other laptops.
    You will use the light blue Tip # M31
    [​IMG]
    Specifications
    Model Luxa2EnerG 65W Universal Adapter
    Part Number PO-ULA-PC65BK-00
    Color Black
    Power Tips 10 Removable Power Tips that set Charging Power
    LED Blue LED Power Indicator
    Protection Circuitry Over-Temperature Protection
    Over-Voltage Protection
    Over-Current Protection
    Short-Circuit Protection
    Certifications CE, FCC, RoHS, UL
    Input Voltage 110 ~ 240Vac / 50 ~ 60Hz
    Output Voltage Laptop Output: 16.0 ~ 20.0Vdc, 65W Maximum
    Voltage selected by Power Tip
    Power Tips 10 Removable Power Tips that also select the voltage
    Dimensions 110 x 48 x 30mm
    Net Weight 290g
    Price: $38 Canadian
    https://www.memoryexpress.com/Products/MX57878
    huthamcau and elDaz_2 like this.
  4. SolidGoomba
    SolidGoomba UDOOer
    Apr 17, 2019
    27
    13
  5. elDaz_2
    elDaz_2 New Member
    Apr 17, 2019
    11
    + 1 for Model Luxa2EnerG 65W Universal Adapter
  6. Kadel
    Kadel New Member
    Apr 20, 2019
  7. chrisr
    chrisr UDOOer
    Nov 1, 2013
    27
  8. ccs_hello
    536
    194
    Verified working 26800mAh (96.5 Wh) USB-C PD 60W power bank can supply up to 20V 3A.
    Search ebay 26800mAh PD 60W Type-C power bank
    Price is around $38 to $42 shipped.
    It can be charged thru USB-C (using the same USB-C port thus cannot be used as simultaneous charge-n-powering at the same time) at max of 30W.
    Mfg/model: Floureon C908-PD
    P.S. it weights around 630 grams (heavy)
  9. Chad Ringstrom
    Apr 17, 2019
    16
    13
    That’s awesome thanks! I was having difficulty finding one under $80-100
  10. Amir
    Amir New Member
    Apr 17, 2019
    Anyone in the UK? what power supply works best here?
  11. chrisr
    chrisr UDOOer
    Nov 1, 2013
    27
    See my post above for eBay link to HP Pavilion power supply. Works well and under £10
  12. Amir
    Amir New Member
    Apr 17, 2019
    @chrisr, thanks for pointing that. HP power supplies are really solid and this is a good price for one; I'll look into it.
  13. Stefano Tognon
    Stefano Tognon UDOOer
    Nov 10, 2017
    15
  14. Petr Zahnas
    Petr Zahnas New Member
    May 2, 2017
  15. MattB
    MattB New Member
    May 31, 2019
    I found that this power supply from Monoprice works quite well. Having the extra USB ports for charging other devices is a bonus.
    https://www.monoprice.com/product?p_id=24425
    It goes on sale occasionally for $20-22, but even at $25 it's a pretty good charger. Note that it doesn't come with a USB-C cable.
    This charger from Nektek on Amazon is the same charger, but includes a 3ft USB-C cable.
    For $30 and fast shipping for Prime members, it's a good deal if you need it quickly.
    I own both charges and they are identical other than the brand printed on them and the color of the USB-A ports (Monoprice ports have a red tab inside). I've been using them for months without issues. I keep one in my bag when I travel. The USB-C port provides enough power to charge my Latitude 7880, my Google Pixelbook, or my Galaxy S9+. Now it can also power my Bolt once I have a case to carry it around in.
    I can also confirm that the HP Pavilion adapter mentioned above works fine. I used the one from my wife's laptop and it worked without issue.
    I pre-ordered a Zendure SuperTank and will report back once I receive it and test. I don't expect any issues though.
    https://zendure.com/products/supertank-black
  16. Akinwale
    Akinwale New Member
    Jul 18, 2019
    I can confirm that the Apple 61W USB-C power supply works fine. You'd need to get a reliable USB-C to USB-C cable for power delivery.
  17. jfs10
    jfs10 UDOOer
    Apr 16, 2019
    22
  18. ccs_hello
    536
    194
    USB-C based power supply needs to be able to offer:
    PD 2.0 20V 3A profile (id: 0x5161).
  19. jfs10
    jfs10 UDOOer
    Apr 16, 2019
    22
    I had been leaving my Bolt on 24x7, but it shutdown on me twice. Both times that it shutdown on me when not in use. Sitting idle that is. It think it would run for about 36hrs or so before shutting down. @ccs_hello pointed out that the power supply has a thermal shutdown. I now think this might be the cause of my shutdown issue. So, don't buy this yet. I hope to update in a week or so.
  20. Gerry Havinga
    Gerry Havinga UDOOer
    Jul 25, 2019
    I purchased "Universal laptop adapter 45W-65W-90W - Asus - Acer-HP - Dell - Lenovo - Samsung - Sony - Zedar" from a make called Zedra. Works fine, but I am not leaving my Bolt running 24/7 at the moment.
