Power supply for UDOOx6 plus ...
Discussion in 'UDOO X86' started by eastsidebuzz, Jan 15, 2018.
  1. eastsidebuzz
    eastsidebuzz New Member
    Jan 15, 2018
    Tolerance on Output 12V is 10%. Udoo X86 needs +/- 5%. It depends on how you interpret this tolerance of the power supply but it can be out of spec.
  3. ccs_hello
    536
    194
    Power supply designed for LED strip has very poor output voltage regulation and high ripple.
    They cheap out on the output side filter capacitors (picked a small value, LED does not care too much...)
    Once you find a proper model (even a low-end power supply unit cheap out), add a large cap (say 2000uF - 4700uF 25V) on the DC output side.
  4. eastsidebuzz
    Jan 15, 2018
    OH Good info. I did not buy it I was just looking. I would be happy to use the udoo power supply. I guess I will take it apart and see if it fits into my 1ru enclosure and then add a PS for the hard drive seperate inside. I dont know the tollarences and the large cap thing went over my head.
