Python I2C
Discussion in 'General Programming Discussion' started by DaViper, Jan 10, 2014.
  1. DaViper
    DaViper New Member
    Jan 8, 2014
    Hey all,
    has anyone been using i2c on Udoo with python? If so, which library would that be? I tried smbus, but that does not seem to exist
    from smbus import SMBus
    ImportError: No module named smbus
    I am trying to communicate to a TEA5767 radio module via i2c from the linux command line using python.
    Any help would be appreciated.
    K.R.
  2. DaViper
    DaViper New Member
    Jan 8, 2014
    fixed it.
    had to install smbus via pip.
    now the GPIO module is remaining
  3. TomFreudenberg
    TomFreudenberg Member
    May 12, 2014
    59
    Have you been able to use I2C with a python script from Linux side?
    If yes, could you be so please and publish your demo command.
    I have tried a lot but was not able to communicate with linux i2c.
    Thanks for some help if possible.
  4. peter247
    peter247 New Member
    Mar 10, 2014
    263
    Hows that theory going ?
    I`ve programmed in python using smb-dev library on the raspberry pi , so IF the port is working it shouldn`t be any different to that.
    Have you tried using i2cdetect -y 0 ( i2c-tools ) and see if it finds your device ?
  5. peter247
    peter247 New Member
    Mar 10, 2014
    263
    I tried pip install smbus and got this :-
    Could not find any downloads that satisfy the requirement smbus
    No distributions at all found for smbus
    The RIGHT WAY is apt-get install python-smbus !!!!!
