SATA M.2 Compatibility List
Discussion in 'UDOO BOLT' started by Sebastiaan van Doorn, Jan 12, 2020.
  1. Sebastiaan van Doorn
    Sebastiaan van Doorn New Member
    Jan 7, 2020
    Hi, I couldn't find a compatibility List for the M.2 B. key so I thought it would be good to start one.
    I have a question to start with. The M.2 B port has space for 2260 sized storage. Is there any possible way to make use of 2280 sized storage module?
  2. ccs_hello
    536
    194
    Only 2242 or 2260 sized key-B M.2 SATA SSD.
    2280 type, you'll have to be "creative" (conflict with key-M 2280 space.)
    Depend on actual layout and tolerance, very limited configurations may work out.
    P.S. I think you know already, BOLT's key-M slot does not support SATA.
    Also, regular SATA is another option.
    evaloverde likes this.
  3. Clunion
    Clunion New Member
    Apr 10, 2023
    I can confirm that the Transcend M.2 SSD 430S (SATA III 6Gb/s)
    works in the M.2 socket CN18 (above the M.2 connectivity socket).
    I was a bit worried because the SSD-drive connector has 2 notches while the socket has only 1 dent
    but looking closely at the table in the manual shows the pins (59-68) at the location of the second notch ar not used.
