Hi. my project consists in the creation of a sensors network between two (or more) Arduino 2 (the coordinator is the Arduino of Udoo) . The communication is implemented with the Xbee module. I have the necessity to realize the interface of the data (of sensors) in Java. The problem is here, because both Xbee and java use the serial communication with Arduino. Someone can help me? Is it possible to send the Arduino data to the Udoo without serial communication (using Java)?
If i got it right you can connect the xbee module to one of the other Arduino 2 serials (pins from 14 to 19: Serial 3(14-15) Serial 2(16-17 Serial 1 (18-19)) leaving the standard serial connection (pin 0-1) for the Java! Here's the pinout diagram: http://udoo.org/download/files/pinout/U ... iagram.pdf
