Serial console from external USB (J18 unplugged)
Discussion in 'Arduino IDE' started by mirots, Jan 7, 2014.
  1. mirots
    mirots New Member
    Dec 26, 2013
    15
    Hi guys,
    I am trying to download Hello World sketch through patched Arduino IDE (1.5.3) to the board, using USB cable attached to CN6.
    It downloads and verifies ok, but when I try to connect to the same port with Serial Monitor - it displays nothing.....
    Am I missing something?
    Thanks
    Meir Tseitlin
  2. mirots
    mirots New Member
    Dec 26, 2013
    15
    Well, my problem is more concrete:
    The sketch does run, but attaching the Serial Monitor is not triggering Atmel Reset....
    Is it by design?
  3. delba
    1,064
    mirots, yes i can confirm that the Serial Monitor is not triggering the Atmel Reset by design.
  4. Icarus
    Icarus New Member
    Apr 17, 2014
    Hi, I had the same problem. For solve:
    1. Install driver usb-serial bridge (if don't install).
    2. Conect usb to CN6 with jumper J18 plugged.
    3. Open generic terminal to port with 115200 baud.
    4. Before the counter reaches 0, press any key on the external PC’ s serial console.
    5. Close the serial monitor and unplug J18 jumper. This will allow the communication with the programming port of SAM3X8E.
    6. Plug the jumper J22 for 1 second, then remove it (to erase the old sketch programmed in SAM3X8E).
    7. Plug the jumper J16 for 1 second, thend remove it (to reset the SAM3X8E).
    8. Select from the IDE: Tools –> Board –> Arduino DUE programming port and select the correct serial COM from the IDE.
    9. Send the sketch using the IDE upload button.
  5. Andrea Arezzini
    Andrea Arezzini New Member
    Jul 15, 2015
    11
    excuse me for the ignorance but i very don't know what j18, j16 and j22 jumper refers and how can i connect this jumper because you said that i have to connect this jumper but i don't know how and to what! Sorry again for my bad english but i hope to be enough clear and i hope someone help me to clarify this doubt.
  6. Andrea Rovai
