Serial Port not working
Discussion in 'UDOO NEO' started by pavan, Jul 12, 2019.
Tags:
  1. pavan
    pavan UDOOer
    Jul 6, 2019
    serial port not working in UDOO neo.
    Can any one help to resolve the issue.
  2. evaloverde
    Apr 29, 2019
    59
    16
    Ciao Pavan, could you please provide more details? We need them to help resole your issue
    ektor5 likes this.
  3. pavan
    pavan UDOOer
    Jul 6, 2019
    sudo ./mkudoobuntu.sh udoo-neo desktop
    Using above command i was create *.img file and after that i was flashed to SD card.
    Inserted to UDOO-NEO board. That time
    UART_1_TX 47 UART1_TXD GPIO_4 IOMUXC_SW_MUX_CTL_PAD_GPIO1_IO04 ALT0 - UART1_TX_DATA
    UART_1_RX 46 UART1_RXD GPIO_5 IOMUXC_SW_MUX_CTL_PAD_GPIO1_IO05 ALT0 - UART1_RX_DATA
    This pins connected to DB9 female connected and female connector. Like below.
    <UDOO-NEO> ==> (46,47) <====> DB9 female connector <===> USB-serial cable <====> PC
    Cable not problem, it working i was used for other also.
    In minicom following configurations i have done: ( same as showed in udoo-doc site)
    | A - Serial Device : /dev/ttyUSB0 |
    | B - Lockfile Location : /var/lock |
    | C - Callin Program : |
    | D - Callout Program : |
    | E - Bps/Par/Bits : 115200 8N1 |
    | F - Hardware Flow Control : No |
    | G - Software Flow Control : No |
    In Minicom terminal showing all "JUNK VALUES"
    This is the problem.
    Thanks,
    Pavan.
  4. ektor5
    Jul 1, 2013
    91
    38
    Hi @pavan,
    Have you tried with the precompiled official images in the Download section?
    https://www.udoo.org/downloads/
    Also, send the model of the serial adapter and post a picture of the setup.
    Thanks,
    Ek5
    evaloverde likes this.
  5. pavan
    pavan UDOOer
    Jul 6, 2019
    Hi Ektor,
    Thanks for response.
    I have tried two official images, still i am facing same issue. "Junk values" displaying in minicom.
    https://www.udoo.org/downloads/ == > below two image collected from this link.
    udoobuntu-udoo-neo-desktop_2.3.0.zip
    udoobuntu-udoo-neo-minimal_2.3.0.zip
    dmesg of serial console after connect.
    [20628.388413] usb 2-2: new full-speed USB device number 18 using xhci_hcd
    [20628.542764] usb 2-2: New USB device found, idVendor=0403, idProduct=6001
    [20628.542768] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
    [20628.542771] usb 2-2: Product: USB Serial Converter
    [20628.542773] usb 2-2: Manufacturer: FTDI
    [20628.542775] usb 2-2: SerialNumber: FTAJM0V7
    [20628.546249] ftdi_sio 2-2:1.0: FTDI USB Serial Device converter detected
    [20628.546317] usb 2-2: Detected FT232RL
    [20628.546542] usb 2-2: FTDI USB Serial Device converter now attached to ttyUSB0
    With other serial cable also tried, same problem in that cable also.
    UDOO NEO
    UART_1_TX 47 ==> 2 Pin of DB9
    UART_1_RX 46 ==> 3 Pin of DB9
    GND pin ==> 5 Pin of DB9
    Still if any thing wrong in my procedure, please tell me.
    Thanks,
    Pavan.
  6. waltervl
    2,022
    510
    evaloverde and ektor5 like this.
  7. pavan
    pavan UDOOer
    Jul 6, 2019
  8. pavan
    pavan UDOOer
    Jul 6, 2019
    Hi Ek5, waltervl and team,
    Thanks a lot .... i have tried with "cp21x converter" same cable. Now it is working fine ... :).
  9. pavan
    pavan UDOOer
    Jul 6, 2019
    Hi Team,
    How to create own SD card partition and how to write SPL,Uboot to SD card.
    While write to SD card i am facing below issue.
    Could you please help on this.
    linux$
    linux$ lsblk
    NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
    sda 8:0 0 465.8G 0 disk
    ├─sda1 8:1 0 95.4G 0 part /
    ├─sda2 8:2 0 3.8G 0 part [SWAP]
    ├─sda3 8:3 0 250G 0 part /media/linux/d3013e39-a19c-402e-8736-0ccd0b2bb896
    └─sda4 8:4 0 116.6G 0 part /media/linux/3b7afe20-bab2-406a-8c64-811e78f911e2
    sdb 8:16 1 7.5G 0 disk
    ├─sdb1 8:17 1 32M 0 part /media/linux/boot1
    └─sdb2 8:18 1 2.6G 0 part /media/linux/udoobuntu
    sr0 11:0 1 1024M 0 rom
    linux$
    linux$
    linux$
    linux$
    linux$
    linux$ ls
    SPL u-boot.img zImage dts
    System.map
    linux$ sudo dd if=SPL of=/dev/sdb1 seek=1 bs=1k
    [sudo] password for linux:
    31+0 records in
    31+0 records out
    31744 bytes (32 kB, 31 KiB) copied, 0.000417137 s, 76.1 MB/s
    linux$
    linux$
    linux$ ls
    System.map
    linux$
    linux$ sudo dd if=u-boot.img of=/dev/sdb1 seek=69 bs=1k
    230+1 records in
    230+1 records out
    236260 bytes (236 kB, 231 KiB) copied, 0.00160651 s, 147 MB/s
    linux$ sync
    linux$
    linux$
    linux$
    ls: cannot access ''$'\022''± 2ε╥'$'\a''ε.Ü_'$'\001': Input/output error
    ls: cannot access ''$'\b''╨"f'$'\v''h'$'\f''i.'$'\001''<'$'\r': Input/output error
    ls: cannot access ''$'\a''εü?'$'\001''≡.'$'\b''╡ ': Input/output error
    ls: cannot access 'ಠ≈m '$'\001''≡.╣² ': Input/output error
    ls: cannot access ''$'\003''╤'$'\001'')'$'\024''┐c#.g#┬': Input/output error
    ls: cannot access ''$'\032''`,J.ó⌡µ': Input/output error
    ls: cannot access 'w └≤'$'\a''0c(.'$'\005''╤ ': Input/output error
    ls: cannot access 'pG.'$'\b''╡ ': Input/output error
    ls: cannot access '#╨'$'\022''KÜi┬≤.AQ┬': Input/output error
    ls: cannot access ''$'\t\003\003''çpgpg.'$'\017''jo': Input/output error
    ls: cannot access ''$'\a''╤'$'\002''≡'$'\003\003\006''!.[': Input/output error
    ls: cannot access '¿°éç.'$'\001''(s': Input/output error
    ls: cannot access 'hfú@'$'\005''Ω'$'\003\001''.ß@'$'\035': Input/output error
    ls: cannot access '─≤'$'\002''D'$'\003''⌠.'$'\b''α─': Input/output error
    ls: cannot access ''$'\032''o'$'\020''▒B⌠@R.'$'\001''α"': Input/output error
    ls: cannot access ''$'\002''(ö┐'$'\030''F.)α'$'\003': Input/output error
    ls: cannot access '└≤ü@'$'\002''('$'\017''╨.'$'\003''('$'\022': Input/output error
    ls: cannot access '@q!⌠@aög.┘j!': Input/output error
    ls: cannot access 'nk'$'\033''h▄ic'$'\006''.'$'\005''╘ ': Input/output error
    ls: cannot access '┬≤Aq┬≤┬T.'$'\002'')'$'\020': Input/output error
    ls: cannot access '/k.'$'\024''0x': No such file or directory
    '¥· !'$'\001''¬.'$'\f''┐'$'\023' ''$'\036''H'$'\003''⌐'$'\n''≡Φ■'
    ''$'\001''.'$'\022''&' '%H'$'\v''≡├ #i.$H'
    '▐└¡'$'\v' ''$'\b''╡'$'\b''h'$'\v''≡'$'\002'' .l≥p'
    '╔.'$'\003\003''[' '-I'$'\033''≡Ä√.∞╨0'
    '╛.'$'\024''≡ƒ' ''$'\003''!'$'\032''≡î■'$'\a''f'
    '╦■."≡'$'\017' '¬i+`Za.p╜8'
    '■≈\■'$'\f'' ■≈.'$'\025''ⁿ'$'\004' '#╣'$'\003''i'$'\023''╣.╜Φ°'
    ''$'\004''≡≡'$'\005\004''≡'$'\017\004''.└≤'$'\a' 'i·'$'\001''≡»·╜Φ.'$'\b''@'$'\f'
    ''$'\a''╤'$'\002''≡'$'\003\003\006''!.[' jfrnsfjf.Rnô
    ''$'\b''╜' 'jh╤p.B°'$'\b'
    ''$'\t''.'$'\002' ''$'\032''`,J.ó⌡µ'
    ''$'\f''≡┤ⁿ'$'\001''! |.'$'\t''%'$'\021' ''$'\001\002\032''`'$'\024''JO⌠.ös'$'\023'
    ''$'\r' ''$'\002''J'$'\023''`pG.'$'\004''!á'
    ''$'\r' ''\''j'$'\022''α ≈â .&i'$'\a'
    ''$'\r' '/k.'$'\024''0x'
    ''$'\r' ''$'\027''k.'$'\024''0X'
    ''$'\r' 'KF'$'\033''hs╡'$'\005''F.'$'\033''l'$'\001'
    ''$'\r' '┌`kf[n4j.'$'\032''ak'
    ''$'\r' '≤╨'$'\036''K'$'\032''hB≡.'$'\001\002\032'
    ''$'\020''.,' ''$'\t''k'$'\034''h. h)'
    ''$'\022''.'$'\037\020' '┌küc┌k'$'\020'':.┌cp'
    ''$'\035''°.'$'\001''*'$'\001' 'k■'$'\001''Ü F.!."≡?'
    ''$'\a''0c('$'\006''╤■≈.ô └' '#╨'$'\022''KÜi┬≤.AQ┬'
    '■≈╢■└≤'$'\a''0.d('$'\004' 'l╣'$'\004''6'$'\b''.±╨.°τq'
    ''$'\a''°└≤'$'\a''0f(.'$'\v''╨ ' L⌠çç╣CÇç.,
    ''$'\a''.0f ' ''$'\n'' LF ≈╓ⁿ.─°╨'
    linux$
    linux$
    linux$
    linux$
    After writing SPL and Uboot to SD card, displaying above junk values.
    Can you please suggest me, how to write SPL and Uboot.img file to SD card.
    Thanks,
    Pavan.
  10. waltervl
    2,022
    510
    Please make a new topic for this issue. Personally I have no idea what coused your issue (if it is an issue).
    Try another SD card to double check?
  11. pavan
    pavan UDOOer
    Jul 6, 2019
    thanks for reply ..
    I have tried with two SD card, with two SD cards i have faced same issue.
    Can you please send me in details steps for create SD card.
    Then i will try one more time on this.
  12. waltervl
    2,022
    510
    I have never done this so I cannot help you. There is only the documentation but you have found that yourself.
