Serial0.print hangs with UART5 + UART2 plugged
Discussion in 'UDOO NEO' started by Gorgo, Nov 23, 2016.
  1. Gorgo
    Gorgo UDOOer
    Nov 9, 2016
    159
    17
    Hi guys!
    Problem:
    Sketch hangs when I use Serial0 + 5V+3.3V sensors. I had to remove the sketch file and reboot in order to upload a new one. (UDOONeo M4 Sketch STOP failed: reboot system !)
    My configuration:
    - Udoo Neo Full
    - RTC + Pressure sensors + GPS (3.3V)
    - Pollution + DHT (5V)
    - 12V power supplier
    If I pin both 5V and 3.3V on my breadboard, the sketch starts printing and it stops eventually after 5/6 prints. If I only plug one set of them (3.3 or 5), it works, the Serial0 doesn't stop.
    The pollution sensor writes to Serial0 RX pin (UART5) while the DHT sensor is linked to GPIO_140.
    On 3.3V side, the RCT SDA/SCL is linked to UDOO SDA/SCL, RCT SQW to GPIO_124; GPS 3.3V input/ground with the breadboard and from the sensor towards GPIO_6 and GPIO_7 (UART2). The pressure sensor is on the same row of the RTC. Even SDA/SCL they're connected to Udoo SDA/SCL.
    Sketch:
    #define LENG 31
    unsigned char buf[LENG];
    void setup(){
      Serial.begin(115200); //Serial is Linux side
      Serial.println("Serial begin OK...");
      Serial0.begin(9600);
      Serial0.setTimeout(1500);
    void loop(){
      byte b=0;
      while(b != 0x42){
        b = Serial0.read();
        delay(100);
      Serial0.readBytes(buf,LENG);
      Serial.println("Loop...");
      Serial.flush();
      delay(500);
  2. Gorgo
    Gorgo UDOOer
    Nov 9, 2016
    159
    17
    Ok Update:
    The guilty sensor seems to be the pressure one.
    If it has power but it's not connected to UDOO, the sketch keeps running.
    I I plug it to GPIO 6 and 7 (UART2_TX and UART2_RX) it hangs.
    Is there a conflict between Serial0 and UART2 an UART5?
    Edit:
    the guilty sensor is definitely the GPS SENSOR.
    Pin recap: at the moment it's powered with 3.3V it communicates to UART2 (GPIO_6 and 7).
    If both pollution (that communicates to UART5) and GPS are plugged with UARTs, the sketch hangs if I use Serial0.
    If I unplugged GPS's pins to UART2, the sketch works.
    At this very moment, I swapped GPS TX/RX, the sketch works, but I have to check if GPS is working fine.
    The question remains: Why this behaviour if I'm using both UARTs? Am I missing something?
  3. Gorgo
    Gorgo UDOOer
    Nov 9, 2016
    159
    17
    I've edited my previous message with new details.
  4. Maurice
    Maurice Active Member
    Oct 13, 2015
    394
    87
    I've only used both UARTs in a simple test program, where the Neo was the sender and the Mega was the receiver. I have had it running for quite a while and I had no problems.
    However, I'll be using Mega<->M4<->iMX.6 communication soon. If I run into something I'm sure to post it at this forum.
  5. waltervl
    According this documentation UART2 is only for debugging the M4 so connecting devices to this serial could have strange effects. How are you reading this serial in your sketch?
    Also using 5V is dangerous for the Neo as the Neo is a 3.3V board.
  6. Gorgo
    Gorgo UDOOer
    Nov 9, 2016
    159
    17
  7. waltervl
    As long as the 5V powered sensor is not sending 5V signals out there is no issue. But normally they don't unless they have a 3.3V/5V switch.
