Service after sale
Discussion in 'General Discussion' started by vinny74man, Jan 19, 2015.
  1. vinny74man
    vinny74man New Member
    Jan 19, 2015
    Hello everyone sorry but I do not know how to get help for product not working.
    UDOO quad purchased in December yesterday after weeks of inactivity the power back and no longer supplied with power supply 12V tried to install the operating system several times but nothing.
    SD 32Gb Kingstone Udoobuntu OS 1.1, connect to the TV via HDMI, but nothing even the network is KO.
    I ask for help for hardware service after sale.
    Thank You
    P.S. This is a translation online
    Ciao a tutti scusate ma non so come fare per richiedere assistenza per prodotto non funzionante.
    UDOO quad acquistato a dicembre ieri dopo settimane di inattività lo riaccendo e non va più alimentato con alimentatore 12V provato ad installare più volte sistema operativo ma nulla.
    SD Kingstone 32Gb SO Udoobuntu 1.1, collego alla tv tramite HDMI ma nulla anche la rete è KO.
    Chiedo aiuto per assistenza hardware dopo vendita.
    Grazie
  2. delba
    1,064
  3. vinny74man
    Jan 19, 2015
    Executed test debug but nothing with putty always black screen, changed OS and micro sd, but nothing, opened two tickets but I can not see the state as not I register to the customer care and can not figure out where to find the ticket number .
    Thank You
    Eseguito prova debug ma niente con putty sempre schermo nero, cambiato OS e micro sd, ma nulla, aperto due ticket ma non riesco a visualizzare lo stato in quanto non riesco a registrarmi al costumer care e non riesco a capire dove reperire il numero del ticket.
    Grazie
  4. vinny74man
    Jan 19, 2015
    U-Boot 2009.08-svn82 (Oct 07 2013 - 13:43:50)
    CPU: Freescale i.MX6 family TO1.2 at 792 MHz
    Thermal sensor with ratio = 177
    Temperature: 24 C, calibration data 0x55e4c169
    mx6q pll1: 792MHz
    mx6q pll2: 528MHz
    mx6q pll3: 480MHz
    mx6q pll8: 50MHz
    ipg clock : 66000000Hz
    ipg per clock : 66000000Hz
    uart clock : 80000000Hz
    cspi clock : 60000000Hz
    ahb clock : 132000000Hz
    axi clock : 264000000Hz
    emi_slow clock: 132000000Hz
    ddr clock : 528000000Hz
    usdhc1 clock : 198000000Hz
    usdhc2 clock : 198000000Hz
    usdhc3 clock : 198000000Hz
    usdhc4 clock : 198000000Hz
    nfc clock : 24000000Hz
    Board: i.MX6Q-UDOO: unknown-board Board: 0x63012 [POR]
    Boot Device: NOR
    I2C: ready
    DRAM: 1 GB
    MMC:
    [/code]
  5. vinny74man
    Jan 19, 2015
    Ok guys understood what my problem, a bad contact jack power I think is due to the power connector on the board if I hold the jack supply mildly wrong loading of the OS goes on. I will try to change the connector on board.Vi'll let you know
    Ok ragazzi capito qual'è il mio problema,un falso contatto jack alimentazione penso sia dovuto al connettore di alimentazione sulla board se tengo lo jack dell'alimentatore leggermete storto il caricamento dell'OS va avanti. Proverò a cambiare il connettore sulla board.Vi farò sapere
    Grazie
  6. delba
    1,064
    Ok, let us know ;)
