Setting up OpenCv in Qt
Discussion in 'General Programming Discussion' started by ji11x38, Nov 4, 2013.
  1. ji11x38
    ji11x38 New Member
    Nov 4, 2013
    22
    HOW TO SETUP OPENCV ON YOUR UDOO AND WRITE A SAMPLE-PROGRAMM
    1. installing neccessary packages:
    Open up a Terminal [ctrl +alt + t] and install a few packages we will need later on via
      sudo apt-get install build-essential cmake cmake-gui git git-gui libgtk2.0-dev pkg-config python-dev python-numpy libavcodec-dev libavformat-dev libswscale-dev
    2.Download the OpenCV- Source and unpack it
    -> Unpack the .tar via an archiv-manager or via consol (sudo tar -xvf filenameXXX.tar )
    4.Now, in your terminal, make sure you are within the OpenCV directory and run the following commands :
    To create a build-folder:
    mkdir build
    	cd build
    to get cmake happy
    	cmake -D WITH_TBB=ON -D BUILD_NEW_PYTHON_SUPPORT=ON -D WITH_V4L=ON -D INSTALL_C_EXAMPLES=ON -D INSTALL_PYTHON_EXAMPLES=ON -D BUILD_EXAMPLES=ON -D WITH_QT=ON -D WITH_OPENGL=ON ..
    and to build
    make
    -> have not done the next step yet but you should
    sudo make install
    5. If everything went the way it should, you are now a proud owner of an Udoo-build Version of OpenCV!
    Or not..... :|
    Would be cool if somebody would take a look at this! have fun and keep up udooing :ugeek:
    ji11x38
  2. Lifeboat_Jim
    Lifeboat_Jim New Member
    Sep 16, 2013
    399
    There is an OpenCV thread already.
    It's not resolved yet, but perhaps between you and the others interested in this topic you can sort it between you by comparing notes/teaming up?
  3. ji11x38
    ji11x38 New Member
    Nov 4, 2013
    22
    -Deleted
  4. jaeg
    jaeg Member
    Oct 22, 2013
    62
    When the build crashes what error messages are you getting?
  5. jaeg
    jaeg Member
    Oct 22, 2013
    62
    Just tried compiling it this is the error I get:
    EDIT - I got it to build. I had to turn QT and OpenGL off with CMake. I had to fiddle with the device # to capture the image from the camera but I got the examples where it puts a circle around a color working
  6. ji11x38
    ji11x38 New Member
    Nov 4, 2013
    22
    Hey jaeg,
    that sounds great!
    Didn't had time to post anything else yesterday....had some errors on building the opencv core what seems logic reading your post on disabling opengl!
    Will give it a try as soon as possible!
    After getting things running, i am going to update the how-to in my first post.
    Maybe an admin could make a sticky of this! I believe there are several people who could make use of it!
    Ji11x38
  7. ji11x38
    ji11x38 New Member
    Nov 4, 2013
    22
    Me again.. Been working the whole evening and did't get any better results... could you please tell me how you managed to get things done? as exact as possible please.
    Where you referring to my how to ?
    if so, did you install all of the necessary packs of step one ?
    Working for quite a while (and to new images) i am getting lots of errors since some of them depend on the libegl1 and libegl2 (i know that we are not supposed to install them due to them breaking opencl-compatibility) dont know if am just missing something (or did an unnecessary extra step)
  8. jaeg
    jaeg Member
    Oct 22, 2013
    62
    I followed this tutorial here:
    http://miloq.blogspot.com/2012/12/insta ... linux.html
    And changed this
    to
    And then it compiled. It took it about 2 hours to finish.
    I'm going to back up my Udoo tonight and try compiling this with the WITH_QT flag ON
    EDIT: I compiled with qt on and got the same error as above.
  9. ji11x38
    ji11x38 New Member
    Nov 4, 2013
    22
    Hi jaeg,
    thanks for your help on getting opencv compiled! Turning off qt and opengl did the job!
    for me the process took also a bit while using 3 of the 4 cores (it seems , that there is not enough ram for running 4 cores at a time..did not try using swap-space yet but it might work out that way! )
    After things where settled in the way of compiling, i am now stuck on getting up a qt project....
    while you can usually create a CMakeLists.txt file with the necessary dependencies location etc. to fire up in the qt-creator, the creator crashs on running cmake.....
    Have you managed to do anything witch opencv or does anybody know how to get the Qt-Creator running as it should?
  10. jykm12
    jykm12 New Member
    Nov 15, 2013
    26
    Please post an update on OpenCV progress for the rest of us.
  11. billy4184
    billy4184 New Member
    Feb 11, 2014
    Hi guys, I got opencv running with GTK by following Ozbot's guide at:
    http://www.ozbotz.org/opencv-installation/
    Feel free to ask me any questions on errors etc as I have spent much time on this problem and can probably point you in the right direction.
    Cheers, Billy
  12. sebasmora
    sebasmora New Member
    Dec 11, 2013
    I try to st up openCV but what i need the most is V4L, not V4L2. Once I build it it says V4L2 yes but V4L no. Any ideas? where can i get this V4L directly?
  13. Tannyveer
    Tannyveer New Member
    Feb 19, 2014
    33
    Hey
    Ozbot's guide: setting up opencvprocedure working on udoo quad board
