Solder Blob on SAM3X ?
Discussion in 'General Discussion' started by sled, Nov 20, 2013.
  1. sled
    sled New Member
    Sep 25, 2013
    I've received my UDOO today and I discovered something that looks like a solder blob, shortening two pins on the SAM3X. Can you tell me if this is "normal" or not?
    Thanks!
    Simon
  2. Lifeboat_Jim
    Lifeboat_Jim New Member
    Sep 16, 2013
    399
    I'd say 'not normal'
  3. sled
    sled New Member
    Sep 25, 2013
    As far as I can tell from the datasheet, it's the PIN 113 and PIN 114 which is PB0 and PB1.
    The UDOO schematic labels PB0 and PB1 with BOOT_SD1 and BOOT_EMMC which definitely shouldn't be shorted afaik.
  4. DracoLlasa
    DracoLlasa UDOOer
    Oct 15, 2013
    419
    it is def not normal, i would suggest you submit a a support request here: http://www.udoo.org/support/contact-us/
    its highly likely that will cause things to not work and it should get fixed. You can try and fix it yourself, but im sure UDOO guys will be willing to replace it once they go through their confirmation process on that sort of thing :)
    They have proven to be very good and reliable about correcting these issues and replacing boards with such problems (though this is the first time im seeing this one)
  5. sled
    sled New Member
    Sep 25, 2013
    I just tried the default SD Linaro image and everything seemed to work even uploading an empty sketch to the arduino worked fine...
