Support for TFAT or TexFAT file systems
Discussion in 'UDOO X86' started by marcello gallucci, Dec 12, 2018.
  1. marcello gallucci
    marcello gallucci New Member
    Dec 12, 2018
    Does the Udoo X86 offer support for TFAT or TexFAT file systems? My application is subject to sudden power loss so I need the Udoo to be able to handle this without corrupting the file system.
  2. itimpi
    itimpi UDOOer
    Oct 31, 2013
    136
    39
    I would have thought this would be a function of the software you are running on the UDOO x86 rather than the hardware? The UDOO x86 is basically just a PC so software that supports these options on a normal PC would probably work on the UDOO x86. Is there any generally available software that supports these file systems?
  3. marcello gallucci
    Dec 12, 2018
    I could be wrong, but as far as I understand, the operating system implements the TFAT file system (for example Windows), but it needs hardware drivers in order to work. The hardware manufacturer provides the drivers, this is why I posted the question.
  4. itimpi
    itimpi UDOOer
    Oct 31, 2013
    136
    39
    I think you will be out of luck then (although it would be nice to be proved wrong) as UDOO do not provide any drivers as far as I know. They rely on the drivers already built into whatever OS you install.
  5. marcello gallucci
    Dec 12, 2018
    According to https://msdn.microsoft.com/en-us/library/aa916300.aspx , "TFAT requires a hardware-specific driver designed for the type of media on which the volume resides. The driver abstracts the media storage and provides atomic block operations". Could it be possible then that it is the hard disk manufacturer that provides this driver? Who provides the standard hard disk of the Udoo X86 models?
  6. Snakebyte
    Snakebyte Member
    Mar 19, 2018
    90
    You do.
