The University here has two WIFI networks, one connects via WEP and the other with WPA. I can connect with the WEP network, but its a pain, as there is a second login step. I have to open a browser and enter my credentials there. This means that after the Neo boots, I can't immediately login. The second network supports WPA only, which eliminates having the second login step. But the Neo doesn't seem to support WPA. In connecting the first time only, I should be asked for my user name and password. But I'm not asked for the user name so the password has no association with a user. Any ideas? Krista
From the command line you should be able to connect via WEP using the iw command, example below: Code: iw dev wlan0 connect <essid> key 0:<key> key is hexadecimal or ASCII value
I'll be digging to learn more about the iw command. As it stands now though, when the Neo boots it appears to reconnect to its last WiFi connection using the same credentials. So there is no issue with connecting with WEP a following time. Just fixed a typo in the original note. It's WPA that the Neo seems to have issues with
Hi Gorgo,I haven't heard of eduroam before so I'll have to dig some to find out what that is. I have seen some vague references to wpa_supplicant, but I don't know what that is, yet.
Hi Krista, Eduroam is a World Wide Education Roaming Wifi but it's available only for the universities that joined the project. If your university has a common WPA network with SSID and a password you can use wpa_supplicant. In order to connect to it change: Code: sudo nano /etc/network/interfaces add: Code: auto wlan0 iface wlan0 inet dhcp wpa-conf /etc/wpa_supplicant.conf and then create /etc/wpa_supplicant.conf with: Code: ctrl_interface=/var/run/wpa_supplicant network={ ssid="YOUR_WIFI_NAME" proto=RSN key_mgmt=WPA-PSK pairwise=CCMP TKIP group=CCMP TKIP psk="YOUR_WIFI_PASSWORD" } Save. Reboot and you should see wlan0 connected with a ipv4. Check it with 'ifconfig'
Thanks Gorgo, things almost makes sense, but our WPA network doesn't have a global network password. Rather, the password is per user. According to our documentation the following are the minimum credentials: Network name: NetworkName Username: Your email name (without the part following "@") Password: Your email password The documentation also says that the following may be needed: Connection type: Infrastructure Security type: WPA2-Enterprise Encryption type: AES Authentication method: PEAP
Ok, in that case we're talking about WPA2-Enterprise that may be more difficult than WPA2-PSK. Eduroam has this kind of configuration. Do you have a certificate too? Sometimes the university gives it to you in a .pem file. For example, my wpa_supplicant for university (UPMC in Paris) is: Code: ctrl_interface=/var/run/wpa_supplicant network={ ssid="NETWORK_NAME" key_mgmt=WPA-EAP pairwise=CCMP group=CCMP TKIP eap=TTLS ca_cert="/home/udooer/.cat_installer/ca.pem" identity="USER@upmc.fr" domain_suffix_match="radius.upmc.fr" phase2="auth=PAP" password="MY_PASSWORD" anonymous_identity="anonymous@upmc.fr" } First try without ca_cert, domain_suffix_match and anonymous_identity. If it doesn't work, check which are your configuration element. In my case we had a website with all the details. In case you have a certificate, be sure to address the correct ca_cert path to your .pem file.
Try also: Code: ctrl_interface=/var/run/wpa_supplicant network={ ssid="NETWORK_NAME" key_mgmt=WPA-EAP eap=PEAP identity="user@example.com" password="password" ca_cert="/etc/cert/ca.pem" (your certificate file) phase2="auth=MSCHAPV2" }
Thanks Gorgo, let's see... in the first cases, after rebooting I wasn't able to reconnect using the network but was able to communicate through the CDC-serial and make changes. In the second case I can connect to 192.168.7.2, but the WPA network is not up. In looking at the ifconfig output I see nothing sent or received, no IP address. One change I made was to remove the ca_cert line.
Yes from your university website, it seems you don't have certificate. Do you get an IP removing ca_cert from the second example?
Hi, thanks so far. What I'm seeing is that the board sits there for a while, I gather that while it's trying to connect the WiFi, other network interfaces are held up. The output from ifconfig doesn't show an inet4 IP address.
Hmm that means it's not connecting... Do 'dmesg' and copy the output. Even /var/log/syslog may be useful. Did you try to remove phase2 too?
Yes, I did remove the phase2 entry as well. Let's see, dmesg produces a significant amount of text so I attached that as a file, the syslog file is even longer.
ctrl_interface=/var/run/wpa_supplicant network={ ssid="NetName" key_mgmt=WPA-EAP eap=PEAP identity="name@TheRest" password="MYPASSWORD" }
Be carefull, according to your university's website, your identity is "Your UofH email name (without the "@hartford.edu" part)". So retry all the combinations we tested, with the new identity.
Ahhh, you are so right. I just retried with the new identity and the Neo came right up, without delay. I can ping off a few off-site URLs. It appears to be working. This makes a difference, thanks much! Besides that, I'm also curious about how the utilities that we just made are related to the desktop tools. I just used VNC to open the desktop and selected Preferences => Network-Connections and don't see the established connection.
So which was the correct configuration at the end? I think if you swap to wpa_supplicant (through /etc/network/interfaces changed) you stop using networkManager. So you won't see an established connection with VNC, even if you're connected. Change the title with [SOLVED] if you can.
