Hi I was looking at using the UDOO camera but was wondering if it's possible to use a USB connector? I read that the camera uses CSI standard and also supports direct show, so it should work via USB if a connector was designed? I am pretty new to this, so i apologize if my question seems dumb. Thanks
No 'cause the camera works via i2c bus, it wasn't designed to work via USB connector. If you want to connect a camera via USB connector you should use a different kind of camera (but you'll need the specific drivers on Linux).
