lvds7 not working with udoo neo. I use standard 12v power supply shipped by http://shop.udoo.org/other/?___from_store=usa&popup=no. As i connect lvds7 to udoo neo and power it up i get a white screen in the lvds7 display and after that display remains white color with no change even if ubuntuneo loads. I tried connecting it with ssh and below are the results. the display is not damaged physically and 12v power supply was used as mention in website kindly help me with this. I tried re downloaded and flash the ubuntuneo image more than 3 times with also no change. everythings works fine when i connect neo with hdmi. kindly help me solve the problem i am facing with neo and lvds7. dmesg http://pastebin.com/PbzzNK4i cmdline console=ttymxc0,115200 root=/dev/mmcblk0p2 rootwait rw ${mmcrootfstype} uart_from_osc clk_ignore_unused cpuidle.off=1 consoleblank=0 uEnu.txt #save this file with unix-like newlines! (\n, 0x0A) video_output=lvds7 m4_enabled=true #m4last=/path/to/arduino/sketch.fw #fdt_file=/path/to/custom/devicetree.dtb
