Udoo Quad problems with Firmata
Discussion in 'UDOO QUAD' started by vinny74, Feb 11, 2016.
  1. vinny74
    vinny74 UDOOer
    Dec 13, 2014
    Hello everyone,
    I am a happy owner of a "udoo Quad". Among other things, recently I started studying "Firmata" with "Python", using "PyFirmata" as well as "PyMata", and in both cases whenever I declare an "Arduino" pin as PWM I encounter a problem. I start the Python sketch and everything goes well. By the end of the sketch, by placing a serial closure command (e.g. board.close ()), the pin declared as PWM turns to the "HIGH" state, and no longer answers requests from PWM. The only way to get it working again is to unplug the power supply.
    Has anyone experienced problems in this regard? Have you solved them?
  2. Andrea Rovai
    Dear vinny74,
    have you checked this page?
  3. vinny_74
    vinny_74 New Member
    Dec 14, 2014
    Grazie per la risposta Andrea
    ma la mia board è una "QUAD" e ho visto che li parla di una "NEO" non so se sia la stessa cosa, comunque ho provato, ma senza risultato utilizzando il "Protocollo Firmata" se non dichiaro il pin come PWM il comando "analogWrite" non produce effetto, però come ho scritto nell'altro post il tutto funziona benissimo fino ha che non chiudo la connessione con la board, dopo di che devo obbligatoriamente riavviarla, staccando l'alimentazione.
    Prove eseguite con "PyMata", "Pyfirmata" e con "Processing" tutte con lo stesso risultato.
    Thanks for the reply Andrea
    but my board is a "QUAD" and saw that it speaks of a "NEO" I do not know whether it is the same thing, though I tried, but without result using the "Firmata Protocol" if you do not declare the pins as PWM command "analogWrite" produces no effect, however, as I wrote another post on everything works fine until it does not close the connection with the board, after which I must necessarily be restarted, disconnecting power.
    Tests carried out with "PyMata", "Pyfirmata" and with "Processing" all with the same result.
    P.S. This is an on-line translation
  4. Andrea Rovai
    UDOObuntu 2 or UDOObuntu 1? Which version, anyway?
    P.S. sorry for my misunderstanding in the first time
  5. vinny_74
    vinny_74 New Member
    Dec 14, 2014
    UDOObuntu 2 rc1 and UDOObuntu 1
    Continuing to make some tests I noticed that even with the sample sketch "DIMMER" I have the same problem, every time I have to use a pin PWM serial presents itself to me the problem, and if I use the sketch "FADE" the changes pin brightness without problems. But if I use the sketch "ReadASCIIString" everything works properly.
    thanks
    Continuando a fare delle prove ho notato che anche con lo sketch di esempio "DIMMER" ho lo stesso problema, ogni volta che devo usare un pin come PWM da seriale mi si presenta il problema, mentre se uso lo sketch "FADE" il pin cambia luminosità senza problemi. Ma se uso lo sketch "ReadASCIIString" tutto funziona correttamente.
    Grazie
  6. vinny_74
    vinny_74 New Member
    Dec 14, 2014
    There is no solution for my problem?
    Non c'è soluzione per il mio problema?
  7. Min Raj Nepali
    Min Raj Nepali New Member
    Mar 4, 2016
    I have a question and it is like:
    I am trying to explore the QUAD Core A9 processor that comes with UDOO Quad. I am trying to use each of them separately as a dedicated processor. I mean i want to run a specific process on a specific core. I have installed Ubuntu provided officially from the site UDOo_Org. when i run top command i can see four cores named cpu0, cpu1, cpu2, cpu3. I want to take control over these processors. How do i start?
  8. waltervl
    This is not a real udoo question but standard Ubuntu: To restrict a process to a specific CPU, you use the command taskset.
    taskset --cpu-list 1,2 my_command
    forces command to run just con CPUs #1 or #2.
    To learn more, type man taskset or search for "linux CPU affinity"
    Andrea Rovai likes this.
