Hi, I've got an Udoo-Quad that run like weather station with some sensor connected to the Arduino pinout... I've now dismiss the weather station and i was re-use the udoo like a server...unfortunately the usb stop working... The 2 usb ports power up the devices, i've try with an external hdd and it turn on correctly, unfortunately on dmesg i cannot find any information about the new devices connected in the usb ports... I've try many devices...Usb mass storage, wifi dongle, mouse/keyboard dongle, webcams... No one appear on dmesg... I've also try some other distribution installed in a fresh SD, but the problem still remain... Have you got some idea on how i can identify the problem? Thanks Ps. with lsusb i can just find the usb hub...
What OS are you running now? Udoobuntu 2? How do you power the QUAD, with a normal 12V, 2A adapter? Can you VNC or SSH the Quad when you connect it with network (LAN)?
1) I've try with UDOObuntu 2.1.2, UDOObuntu v1.1 and Armbian 5.25. 2) I use the stock 220->12v adapter 3) Yes, i can just connect to Udoo over SSH on thernet, because usb keyboard/mouse are not working so i cannot pass the login and use deskop DE
