Udoo x86 don't recognizes sata ports
Discussion in 'UDOO X86' started by Francy2040, Jul 13, 2017.
  1. Francy2040
    Francy2040 New Member
    Jun 20, 2017
    18
    Good evening,I have a big problem.My udoo x86 don't recognizes the 2 sata 3 ports and the 8gb emmc embedded memory
    Into the bios,there is "Sata port #0 not installed" and "sata port #1 not installed"
    Please help me
    2,295
    565
  3. Francy2040
    Jun 20, 2017
    18
    I attached a WD Caviar Blue 1TB 7200rpm hard disk . This hdd is SATA 3
    I tried to install Windows 10 Pro
    Yes,I followed the official official documentation
    I got this message into the BIOS
  4. waltervl
    2,295
    565
    Hi, this hard disk is running on 12V but the Sata power connector on the Udoo X86 is only supplying 5V ( see the hardware user manual on page 30). It is to big for the Udoo to supply power. Udoo X86's are designed for 2.5 inch drives and SSD's which run on 5V only.
    So you have to connect an external 12V Power source to the harddisk and it will run.
  5. waltervl
    2,295
    565
    You have to search on the forum, I believe someone showed his solution for supply 12V to an external hard disk.
  6. waltervl
    2,295
    565
  7. Francy2040
    Jun 20, 2017
    18
    I think I'll buy a SATA 12V connector
    @waltervl
  8. Markus Laire
    Markus Laire Active Member
    Mar 9, 2017
    225
    91
    The problem is not that HDD is "too big" for power supply - the power supply of UDOO X86 could easily handle 3.5" HDD, but UDOO devs seems to have just decided they want UDOO X86 to be user-unfriendly.
  9. waltervl
    2,295
    565
    A SATA output connector has to carry at least 1,5A also on 12V even if it is not used. So this would increase the total potential power supply that the Udoo X86 has to be able to supply with 50% (from 3A to 4.5A).
    If you only use the Udoo for a NAS then it would be OK. If you attach all other kinds of pheripherals and use the Arduino part etc then the current power supply could be too small (just my assumption, not based on actual calculations.... ). The Udoo team has to make decisions based on the intended use.
  10. SteveD
    SteveD Member
    May 5, 2017
    36
  11. Markus Laire
    Mar 9, 2017
    225
    91
    Still I find it strange that UDOO did not want to give users a choice of using 3.5" HDD when it would've cost them absolutely nothing (just add trace from 12V input to SATA power), with perhaps a warning to check power consumption of your HDD (mine is 0.45 A @ 12 V, not a problem at all).
  12. Maurice
    Maurice Active Member
    Oct 13, 2015
    394
    87
    I would like to power 4 3.5" HDDs, in order to use one of the UDOO advanced as a NAS. Any easy way to do so?
  13. sirrab
    sirrab UDOOer
    Jul 26, 2014
    258
    31
    Define "easy"?
  14. sirrab
    sirrab UDOOer
    Jul 26, 2014
    258
    31
    Where are you finding 4 HDD(SATA) data connections?
  15. Maurice
    Oct 13, 2015
    394
    87
    @sirrab In my old Homeserver.
    The power supply is broken, and there is no replacement available. I'd like to get my stuff back and use it again as a NAS and backup server. Saved my day once when we had an 'interpol' hijacker virus.
    [​IMG]
  16. itimpi
    itimpi UDOOer
    Oct 31, 2013
    124
    33
    In another thread
  17. itimpi
    itimpi UDOOer
    Oct 31, 2013
    124
    33
  18. Francy2040
    Jun 20, 2017
    18
    Thanks to all
    I solved buying a new 2,5" SATA 3 SSD
