Udoo X86 News: UEFI (bios) v1.05 and EAPI framework
Discussion in 'UDOO X86' started by waltervl, Nov 20, 2018.
  1. waltervl
    Udoo team silently introduced a new Bios V1.05.
    The only documented change is: Enabled SPDIF-OUT pin on Audio Codec
    More info: https://www.udoo.org/docs-x86/Advanced_Topics/UEFI_update.html
    Also Udoo introduced support for the EAPI Framework: https://www.udoo.org/docs-x86/Advanced_Topics/EAPI.html
    EAPI (Embedded Application Programming Interface) is a framework developed by PICMG® for COM Express modules that gives a common API to unify software control for:
    • System information
    • Watchdog timer
    • I2C Bus
    • Flat Panel brightness control
    • User storage area
    • GPIO
    Laura and goldio like this.
  2. goldio
    goldio New Member
    Apr 14, 2017
    10
    Thanks 4 this info :)
  3. Snakebyte
    Snakebyte Member
    Mar 19, 2018
    90
    BIOS still not open source, updater still limited to selected operating systems. Hard to get excited about it.
  4. itimpi
    itimpi UDOOer
    Oct 31, 2013
    136
    39
    Updated being limited in OS is not really an issue as it is relatively trivial to create a bootable DOS USB and run the updates from there.
  5. Snakebyte
    Snakebyte Member
    Mar 19, 2018
    90
    I'm not clear on this. Where does the DOS come from?
    It doesn't address that the Udoo makers decided to use a closed, proprietary firmware, instead of an open source one. Then some of these bugs could be addressed by the Udoo community.
  6. itimpi
    itimpi UDOOer
    Oct 31, 2013
    136
    39
    That was addressing the comment about the updated only running under certain OS. I was pointing out that anyone who uses an UDOO can easily update the BIOS regardless of what OS is normally used on their UDOO.
    As to whether an Open Source BIOS should have been used I agree it would be nice but I have no information that would allow me to have a view on how difficult it would be to achieve.
  7. Snakebyte
    Snakebyte Member
    Mar 19, 2018
    90
    And I was asking - how? Where does the DOS come from for a "bootable DOS USB?"
  8. itimpi
    itimpi UDOOer
    Oct 31, 2013
    136
    39
    Just download something like Rufus and it has the option to build a bootable DOS USB (based on FreeDOS I believe).
  9. Snakebyte
    Snakebyte Member
    Mar 19, 2018
    90
    And what operating system does Rufus require?
  10. itimpi
    itimpi UDOOer
    Oct 31, 2013
    136
    39
    Rufus is Windows based, but there are equivalents for all common OS.
  11. Laura
    Laura UDOOer
    Apr 22, 2016
    374
    156
    The firmware development team used a solution they implemented in other single-board computers. Shifting to a different solution would have increased the development time and costs of the UDOO X86.
    There is potentially good news on the horizon for those who seek open-source firmware. We are in communication with the coreboot team and recently received an offer of help from a member of their community, who will be exploring the implementation of their open-source firmware onto the UDOO X86.
  12. Snakebyte
    Snakebyte Member
    Mar 19, 2018
    90
    Why not use OpenFirmware? It is BSD-licensed, unlike coreboot. It worked well enough for OLPC and Apple's Old World and New World macs, so it should handle Udoo's needs. I've compiled the source code for both OS X and Haiku on x86 architecture, so it is quite portable. It's also quite extensible. Beware that some developers have corrupted the original OF code with GPL code, but the original source code is still available.
  13. Snakebyte
    Snakebyte Member
    Mar 19, 2018
    90
    This contradicts your earlier statement "I was pointing out that anyone who uses an UDOO can easily update the BIOS regardless of what OS is normally used on their UDOO." Now you have reduced that to "all common OS" and moved away from the Udoo board itself. In other words, if the OS I am running on Udoo now doesn't make bootable DOS USB sticks, I have to resort to using a different OS on different hardware. I think we have different ideas of "relatively trivial," and there are too many assumptions about what developers are doing. Udoo needs to make the BIOS updater (and BIOS itself) available in full under a BSD license to maximize inclusiveness.
  14. itimpi
    itimpi UDOOer
    Oct 31, 2013
    136
    39
    If your OS can write to a USB or a CD then you can create a bootable one.
  15. Snakebyte
    Snakebyte Member
    Mar 19, 2018
    90
    The OS I am using can write to USB and mark the MBR bootable. Where does the DOS come from?
  16. waltervl
  17. itimpi
    itimpi UDOOer
    Oct 31, 2013
    136
    39
    You can get freedos from freedos.org or msdos from anybootdisk.com. Probably other sources of both of those if you google for sources.
  18. Snakebyte
    Snakebyte Member
    Mar 19, 2018
    90
    I believe we've already established that Rufus requires Windows, i.e. another operating system. Assuming this can be done with dd, do I have to install FreeBSD or can their installer run the firmware updater?
  19. Snakebyte
    Snakebyte Member
    Mar 19, 2018
    90
    Are you referring to bootdisk.com? Doesn't look legit.
    Are there any BSD-licensed DOS clones?
  20. waltervl
    Ah, missed that. It think you can use dd or use somthing like this (in the answer) https://superuser.com/questions/1285482/persistent-freedos-live-usb
