Hello~ After setting the static ip in /etc/network/interface, I can not log in the udooer@udooneo via USB cable (ssh 192.168.7.2 by putty). The USB device can be found correctly. But the ssh request always time out. I can not reach the linux terminal now. How to restore the eth0/usb or factory setting? Thanks!
Couple of possible options: 1. connect a HDMI monitor (TV) and keyboard and change the file. 2. Connect it to your local lan with a network cable and ssh on the static IP you have given, or the IP your router has given it. 3. Last resort: create new OS image on the SD card. All changes including the interface file will be lost. I hope you have a backup.
Thanks, waltervl! It's lucky that the img did not crashed, and I restored the network interfaces via UI connecting a HDMI. I'm still interested why the static IP can't be ping successfully, my code is like below in /etc/network/interfaces Code: auto eth0 iface eth0 inet static address xxx.xxx.xxx.xxx broadcast xxx.xxx.xxx.xxx netmask 255.255.255.0 dns-search xxx.xxx.com dns-nameservers xxx.xxx.xxx.xxx BTW if I want to use DHCP, should I enable the syntax : Code: auto eth0 iface eth0 inet dhcp
For some reason (above my knowledge) it has been very difficult to set a static IP through the Neo Ethernet connection configuration. I have set it through my router which is much easier. But you need access to the network router which in professional or educational networks is not always possible. Try searching the neo forum on the word static. It could give you some hints.
