UdooX86 Ultra (old model) Wifi antennas and cables for official Udoo metal case (M2 Wifi BT module)
Discussion in 'UDOO X86' started by stecolumna, Oct 31, 2021.
  1. stecolumna
    stecolumna UDOOer
    May 20, 2016
    158
    38
    Dear Udooers,
    When I bought my UdooX86 Ultra (old model) as soon as it was put on the market after the closing of the Kichstarter campaign I also bought the Wifi and BT M2 module but the antennas were not provided.
    Up to now I have used wifi usb key but now I can no longer install it on Debian 11 so I would like to activate the Wifi module BT M2 with the antennas.
    In the online SBC documentation is described the right model even with the photograph, but I cannot find the product in UdooShop. https://www.udoo.org/docs-x86/Hardware_&_Accessories/Official_Accessories.html
    2x IPEX MFH-4(W.FL) to RP-SMA cables
    2x RP-SMA antennas
    If this product is not available in the UdooShop, please suggest me an Italian distributor where to buy it. I would not like to buy a cable that is not compatible with the connections of the M2 module and the antennas with a ferrule having a pitch different from the hole in the official Udoo metal case.
    Best regards and thanks in advance for the answers,
    Stefano Colonna
    [italiano]
    cari Udooers,
    Quando ho acquistato la mia UdooX86 Ultra (vecchio modello) non appena era stata messa in commercio dopo la chiusura della campagna Kichstarter ho comprato anche il modulo Wifi e BT M2 ma non erano fornite le antenne.
    Fino ad oggi ho usato una chiavetta wifi usb ma ora non riesco più a installarla su Debian 11 quindi vorrei attivare il modulo Wifi BT M2 con le antenne.
    Nella documentazione online della SBC viene descritto il modello giusto anche con la fotografia ma non riesco a trovare il prodotto in UdooShop.
    2x RP-SMA antennas
    Nel caso in cui questo prodotto non fosse disponibile nell'UdooShop vi prego di suggerirmi un distributore italiano dove acquistarlo. Non vorrei comprare un cavo non compatibile con le connessioni del modulo M2 e delle antenne con un una ghiera di passo diverso dal foro presente nel case ufficiale metallico di Udoo.
    Con i migliori saluti e ringraziamenti anticipati per le risposte,
    Stefano Colonna
  2. ccs_hello
    535
    194
    I can offer 1/2 part of the answer...
    The RF connector on the M.2 module will be MHF4 (a.k.a. IPEX4) connector. The tiniest one.
    The other end will be the matching connector for your screw-on rubber-ducky antenna (typically 2.4GHz version.)
    It might be male or female, SMA or other format.
    stecolumna likes this.
  3. stecolumna
    stecolumna UDOOer
    May 20, 2016
    158
    38
    Dear ccs_hello,
    thank you very much for the answer,
    Stefano Colonna
