Upload to Arduino 101 from CLI
Discussion in 'UDOO X86' started by anweiss, Jun 22, 2017.
  1. anweiss
    anweiss New Member
    May 3, 2017
    I'm running Ubuntu Server 16.04 on my Udoo x86 and am trying to program the 101 from the command line. I'm following Arduino's guidance here -> https://github.com/arduino/Arduino/blob/master/build/shared/manpage.adoc ... however, running in to "Flashing is taking longer than expected. Try pressing MASTER_RESET button" issues during upload. I installed the board packages with "arduino --install-boards Intel:arc32" ... and am uploading with this command ->
    arduino --board Intel:arc32:arduino_101 --port /dev/ttyACM0 --upload MyProgram.ino ...
    but am unable to get the upload to succeed. Anyone have success with this? I've applied the 101 udev rules as well.
  2. x1800MODMY360x
    x1800MODMY360x Member
    Mar 29, 2017
    55
  3. anweiss
    anweiss New Member
    May 3, 2017
    Have tried pushing the reset switch ... to no avail. I'm using Arduino 1.8.3 and have applied the udev rules per the script.
    Uploading...
    Starting download script...
    ERROR: Timed out waiting for Arduino 101 on /dev/ttyACM0
    An error occurred while uploading the sketch
  4. waltervl
  5. Tom Barber
    Tom Barber New Member
    Jun 18, 2016
  6. waltervl
  7. Tom Barber
    Jun 18, 2016
    Mine ended up working, for now at least, although i'm not sure how. It put itself into a reset right after boot after a currie bios tweak and the next time I powered up it started writing to it again. I'm not sure if that forced a flush or something, but its working for now.
    I also thought the master reset button just restarted the arduino but I get an OS reboot, so not sure whats going on there either.
  8. waltervl
    If you switched on the Curie/Braswell Power Management then you could get strange results. Also putting Pin 9 Low in a sketch could get strange result.
    I also quote the latest kickstarter update (shame they did not incorperate that in the current documentation)
