The documentation indicates that it is possible to create a USB direct connection to the UDOO Quad. Perhaps it should be obvious, but the documentation does not indicate which microUSB port of the Quad one should use to attempt this. If I use the CN6 port, my Windows 10 PSC recognizes that I've connected to something, but it does not respond as described in the documentation and try to set up an RNDIS device. If I try to force install RNDIS as described in the docs it does not work (with or without J18 connected). If I install the USB to UART driver, it recognizes CN6 as a USB to UART Bridge. If I plug my Windows 10 PC into CN3, it does nothing. Phil
