using MFG-Tool
Discussion in 'Application & Utilities' started by ebito, Nov 22, 2013.
  1. ebito
    ebito New Member
    Jul 3, 2013
    it is possible to use the MFG-Tool to load SW into the RAM?
  2. Lifeboat_Jim
    Lifeboat_Jim New Member
    Sep 16, 2013
    399
  3. ebito
    ebito New Member
    Jul 3, 2013
    hi,
    I know how to use the MFG-Tool. My question is, can it used to transfer software to the I.MX on the UDOO. Because, if the Boot pins set to another boot option, the MFG-Tool can't be used.
  4. Lifeboat_Jim
    Sep 16, 2013
    399
    boot pins.. the resistors you mean. Hmm, I see your point.
    Still if you're brave you can alter those (assuming you don't value the warranty).
  5. miousername
    miousername New Member
    Jun 23, 2013
    73
    I tried mfgtool but it doesn't work, I think that mfgtool uses a custom configuration for mx6 custom board (sabresd, sabrelite) that doesn't match with udoo,so, this tool doesn't work.
  6. ebito
    ebito New Member
    Jul 3, 2013
    have you change the boot_pins?
