V8 not booting correctly
Discussion in 'UDOO BOLT' started by Matthew Epler, Oct 25, 2020.
  1. Matthew Epler
    Matthew Epler UDOOer
    Oct 24, 2020
    After several hours of troubleshooting, I still can't get my V8 to boot correctly.
    Current state: it boots to a blank purple Ubuntu screen.
    Things I've done so far:
    • Installed 20.04 from USB to NVME SSD. It booted once, but never again. Just straight to the BIOS.
    • Tried re-configuring BIOS according to some threads in the forums
    • Installed 20.04 to the eMMC, which booted once successfully (with BIOS restored to orig settings)
    It's really disappointing to spend hundreds of dollars on something that you can't get to work out of the box.
  2. Matthew Epler
    Oct 24, 2020
    Okay, so I'e cooled down and tried some new things which have worked.
    With OS installed on eMMC...
    - unplugged all hard drives
    - rebooted, nothing on screen
    - switched from using the USB-C connector to HDMI, image is up
    - shutdown
    - install one drive, reboot
    - format drive, reboot, it shows
    - install 2nd drive, boot up
    - that one shows, but the 1st one doesn't
    - format the first drive
    - reboot
    - both drives show up
    Seems like the screen issues were related to the USB-C port. HDMI is more reliable. As for the drives, I have no idea why what caused these issues but they seem to be stable now.
    PS - you will need to add permissions to your drives if you use ext4 like I did.
  3. ccs_hello
    536
    194
    Please share NVMe SSD's make/model info. Thx.
  4. Matthew Epler
    Oct 24, 2020
    @css_hello here is a pic for you.
    FWIW after sitting all night not being used, my UDOO now boots up to a grub command prompt. :|
    [​IMG]
  5. Matthew Epler
    Oct 24, 2020
    img didn't work and I can't edit while awaiting moderator approval....wtf
    [​IMG]
  6. ccs_hello
    536
    194
    Also, pls try
    - disable eMMC when loading the OS to NVMe
    - do not install NVMe when loading OS to eMMC
    to see if booting to the OS could work.
