Warning:uploading clean firmware failed
Discussion in 'UDOO NEO' started by klakier2121, Dec 7, 2015.
  1. klakier2121
    klakier2121 Member
    Dec 5, 2015
    48
    15
    Hello when i try to compile any program i get:
    /usr/bin/udooneo-m4uploader: line 78: 14684 Bus error $up "$FW_CLEAN" 2>&1 warning: uploading clean firmware failed
    How to solve this problem?
  2. ddewaele
    ddewaele Member
    Dec 2, 2014
    48
    11
    I'm getting these from time to time
    /usr/bin/udooneo-m4uploader Blink/Blink.cpp.bin
    /usr/bin/udooneo-m4uploader: line 78:  1923 Bus error               $up "$INPUT" 2>&1
    Only solution for now is to power toggle the board
  3. klakier2121
    klakier2121 Member
    Dec 5, 2015
    48
    15
    Now I have:
    /usr/bin/udooneo-m4uploader: line 78:  3134 Bus error               $up "$INPUT" 2>&1
    flash: uploading input firmware failed
  4. Andrea Rovai
    In this case the first suggestion is to reboot the board. After rebooting does it still give you problems?
  5. klakier2121
    klakier2121 Member
    Dec 5, 2015
    48
    15
    Yes after reboot is ok, but when i use SerialPort in arduino sketch it shows again. I have another problem which is connected with previous problem. I have example program:
    int ledPin = 13;
    void setup()
      //Create Serial Object
      Serial.begin(9600);
      pinMode(ledPin, OUTPUT);
    void loop()
      //Have the arduino wait to receive input
      while (Serial.available() == 0);
      //Read the Input
      int val = Serial.read() - '0';
      if (val == 1)
        Serial.println("Led is On");
        digitalWrite(ledPin, HIGH);
      else if (val == 0)
        Serial.println("Led is Off");
        digitalWrite(ledPin, LOW);
      else
        Serial.println("Invalid!");
      Serial.flush();
    When i write something in Serial Monitor nothing happen. Then when i upload next sketch, SerialMonitor once reads the value which i wrote. I dont know what i am doing wrong.
  6. klakier2121
    klakier2121 Member
    Dec 5, 2015
    48
    15
    writing to /dev/ttyMCC is updated every reboot or what ?
  7. klakier2121
    klakier2121 Member
    Dec 5, 2015
    48
    15
    Ok, i solved this problem :) My arduino program was wrong :)
  8. jrullan
    jrullan New Member
    Dec 11, 2014
    28
    @klakier2121 Do you mind telling us what was wrong?
    I have the same problem and I can't see what is wrong in my code.
  9. klakier2121
    klakier2121 Member
    Dec 5, 2015
    48
    15
    I compiled this example program :
    // the setup function runs once when you press reset or power the board
    int led = 13;
    int l;
    void setup() {
      // initialize digital pin 13 as an output.
      pinMode(led, OUTPUT);
      Serial.begin(115200);
    // the loop function runs over and over again forever
    void loop() {
    if(Serial.available() > 0)
      if(l == 1)
      digitalWrite(led, HIGH);   // turn the LED on (HIGH is the voltage level)
     if(l == 0)
      digitalWrite(led, LOW);    // turn the LED off by making the voltage LOW
    and then I run command
    minicom -D /dev/ttyMCC
    when you will wrire 1 or 0, led will flash or not
  10. Watson
    Watson New Member
    Jun 30, 2016
    I'm still having this problem, the reboot do not help. I'm trying to compile my code directly to the M4 core
    (using the NXP's FreeRTOS BSP). I have a simple led blinking example which uses the GPIO_105
    (GPIO4_09) and I don't use any serial port. Does anyone know where should I look for the problem?
    udooer@udooneo:~/vd1209/m4$ udooneo-m4uploader -v blinking_imx_demo_epit_imx6sx_ai_m4.bin
    FILENAME = /boot/m4clean.fw; loadaddr = 0x847c0000
    start - end (0x84780000 - 0x84800000)
    FILENAME = blinking_imx_demo_epit_imx6sx_ai_m4.bin; loadaddr = 0x1fff0000
    start - end (0x1ff80000 - 0x20000000)
    /usr/bin/udooneo-m4uploader: line 86:  1538 Bus error               $up "$INPUT" 2>&1
