Wifi - Disable Wifi mechanicly
Discussion in 'General Discussion' started by Edison, Jan 22, 2014.
  1. Edison
    Edison New Member
    Jan 22, 2014
    Is there a way to disable wifi mechanicly on the Udoo Quad?
  2. delba
    1,064
    Just unplug the module (it has only 1 screw).
  3. direction
    direction New Member
    Feb 25, 2014
    Could you please tell me who is the Wi-Fi module / Chip vendor?
    Also, what is the interface for the Wi-Fi module (SDIO/USB/PCIe?)
  4. delba
    1,064
    The Chip vendor is: gwf-3m08 while the interface for the Wi-Fi module is USB.
  5. direction
    Feb 25, 2014
    Great, the chip vendor is Ralink 5370. I am very ....very familiar with that :D
  6. delba
    1,064
  7. fetcher
    fetcher Member
    Mar 9, 2014
    166
    20
    If you don't need the Wifi module, its 7-pin header can easily be used as a fourth USB port-- just skip pin 1 (closest to the rear of the board), and starting with pin 2 the signals are the same order as for USB port 3 on the 4-pin JST header: +5V, DN, DP, GND. See page 10 of the schematic, lower-left corner.
    The only caveat is that the +5V power connection on this header, unlike the other USB ports doesn't seem to be protected by a fuse, so adding an in-line one somewhere between the header and your USB socket would be a good idea.
