I have MediaAccess TG788vn v2 router from my ISP provider, encrypted wifi with wpa and UDOONEO BASIC KS. I configured wifi by using WPA supplicant. Internet works. But I cannot connect ssh through wifi if I do not reset the router while udooneo device is turned on: marko@marko-laptop:~$ ssh 192.168.1.131 -l udooer ssh: connect to host 192.168.1.131 port 22: No route to host Any clues what could be the problem?
If you connect your NEO with the USB cable and ssh to the well known 192.168.7.2 address, what does ifconfig output?
It looks ok: udooer@udooneo:~$ ifconfig lo Link encap:Local Loopback inet addr:127.0.0.1 Mask:255.0.0.0 inet6 addr: ::1/128 Scope:Host UP LOOPBACK RUNNING MTU:65536 Metric:1 RX packets:4 errors:0 dropped:0 overruns:0 frame:0 TX packets:4 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:0 RX bytes:1168 (1.1 KB) TX bytes:1168 (1.1 KB) usb0 Link encap:Ethernet HWaddr 4e:71:9e:aa:bb:cc inet addr:192.168.7.2 Bcast:192.168.7.3 Mask:255.255.255.252 inet6 addr: fe80::4c71:9eff:feaa:bbcc/64 Scope:Link UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:227 errors:0 dropped:0 overruns:0 frame:0 TX packets:62 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:28893 (28.8 KB) TX bytes:11899 (11.8 KB) wlan0 Link encap:Ethernet HWaddr 5c:31:3e:d5:70:52 inet addr:192.168.1.131 Bcast:192.168.1.255 Mask:255.255.255.0 inet6 addr: fe80::5e31:3eff:fed5:7052/64 Scope:Link UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:97 errors:0 dropped:0 overruns:0 frame:0 TX packets:114 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:11698 (11.6 KB) TX bytes:14279 (14.2 KB) udooer@udooneo:~$ route Kernel IP routing table Destination Gateway Genmask Flags Metric Ref Use Iface default dsldevice.lan 0.0.0.0 UG 0 0 0 wlan0 192.168.1.0 * 255.255.255.0 U 0 0 0 wlan0 192.168.7.0 * 255.255.255.252 U 0 0 0 usb0
Can you ping the Neo from your laptop when the Neo is connected through wifi? Can you see on the router that the Neo is connected? Have you set an fixed/static IP for the Neo? Perhaps the router gets confused when switching from wired to Wifi.
