Building Android Sources (Udoo tar file 1.4) fails
Discussion in 'Android' started by udoid, Apr 6, 2014.
  1. udoid
    udoid New Member
    Mar 2, 2014
    12
    I'm having problems building the latest Udoo Android source release (version 1.4). It fails with this message:
    I have previously built the 1.1 tar file and did not get this error and note that I am using an Ubuntu 12.10 build environment.
    Any suggestions?
    (Or if any of the Udoo development team read this can you give me a hint of what changed between 1.1 and 1.4 tar releases?)
  2. delba
    1,064
  3. udoid
    udoid New Member
    Mar 2, 2014
    12
    Hi delba,
    thanks for your reply. I downloaded and built the 4.3 source ok and my Udoo boots but the touchscreen displays ok but does not respond to touches. All it does is display the 'home' screen. I have the same problem with the 1.1 tar file - builds ok but the touchscreen only displays, does not respond to touch (the 7 inch display).
  4. udoid
    udoid New Member
    Mar 2, 2014
    12
  5. delba
    1,064
    We'll check and re-upload the sources asap. thanks for reporting that.
