Pin number mismatch
Discussion in 'UDOO NEO' started by matib12, Feb 18, 2016.
  1. matib12
    matib12 New Member
    Feb 9, 2016
    17
    I'm developing a code using cross compilation on my PC using Arduino IDE 1.6.5 with the board packet from https://udooboard.github.io/arduino-board-package/package_udoo_index.json. I'm reading pin 11 but its state never changes. I must connect electric signal to the pin 10 in order to obtain change of the value. It is clear to me that there is a mismatch in pin assignment in the library. I'm not able to fix it by myself. Below there is is my Arduino sketch which reproduces the error:
    void setup() {
      // put your setup code here, to run once:
      Serial.begin(115200);
      pinMode(11, INPUT);
    void loop() {
      // put your main code here, to run repeatedly:
      Serial.println(digitalRead(11));
      delay(1000);
  2. matib12
    matib12 New Member
    Feb 9, 2016
    17
    It seems that pin 10 and 11 are swapped.
  3. Andrea Rovai
    Dear @matib12
    first of all, welcome in the forum!
    In a second place, we're aware of this issue. It will be fixed soon
  4. matib12
    matib12 New Member
    Feb 9, 2016
    17
    For those who are eager to fix the problem by their own, you can edit wiring_digital.c file in the board package. First you need to download *.tar file with the board packet and make a local copy of it in the Arduino SDK folder: arduino-1.6.5-r5\hardware\udooboards\udooneo-arduino-solox-1.6.5
    Andrea Rovai likes this.
  5. Andrea Rovai
    Muchas gratias, I'm implementing your solution in the Troubleshooting session, it will soon be ok.
