sd card is read only
Discussion in 'UDOO X86' started by puschkin, Mar 31, 2017.
  1. puschkin
    puschkin New Member
    Jan 24, 2014
    11
    any idea, when that will be available?
    For me its a killer bug right now..
  2. mkopack
    mkopack Member
    407
    Have you tried installing onto a USB 3.0 Thumb drive? Maybe you can use that in the mean time?
  3. Andrea Rovai
    Andrea Rovai Administrator Staff Member
    1,676
    219
    NEWS
    We've fixed the problem of SD being read only.
    Just download the following link
    http://download.udoo.org/files/UDOO_X86/UEFI_update/UDOOX86_B02-UEFI_Update_rel102.zip
    and you'll find inside it a file with the process you have to follow to update the UEFI BIOS, as well as the updater tool.
    This will be the default BIOS from now on for all the news UDOO X86 boards. Those instead who already have the board have just to follow the procedure in the link to update.
    TheCluster likes this.
  4. Jetguy
    Jetguy Member
    Mar 28, 2017
    43
    36
    Thanks for the update, performed on a Win10 install per the PDF in the download and copied the required files to the root of C: to make the path easy. also, I tried the first time and failed to ensure I ran the command prompt as administrator. The application still runs but does not flash. Just a warning to prevent others from skipping that key step. Right click on the icon for the command prompt to see the menu to run as administrator before starting it.
  5. francescomm
    francescomm Member
    Dec 14, 2013
    65
    Thank you.
    Took me some time to understand, so here are the steps on Ubuntu:
    1-unpack zip UDOOX86_B02-UEFI_Update_rel102/
    2- open terminal in subfolder Linux/x64/ (assuming it is a 64bit ubuntu, otherwise ia32)
    3- use the following commands
    chmod +x *.sh
    chmod +x ./x64/H*
    sudo ./bios_updater_x64.sh ../../Bios/0B020000.102
    bpr likes this.
  6. puschkin
    puschkin New Member
    Jan 24, 2014
    11
    Thanks for your hints, now the sd card is working finally!
    In addition you need to make sure, that binutils, gcc and kernel header files are installed, otherwise it will not work!
    Especially, when you have booted a reduced linux distribution that matters.
