Can I use HDMI to output to a Laptop and split screen
Discussion in 'UDOO 101' started by venkat1964, Oct 17, 2013.
  1. venkat1964
    venkat1964 New Member
    Oct 16, 2013
    I am thinking connecting udoo to a laptop for development and using the laptop screen as a split screen between Udoo and PC. Is it possible just using basic hdmi connections etc... Any ideas are welcome. I am just exploring
    Thank You
  2. DracoLlasa
    DracoLlasa UDOOer
    Oct 15, 2013
    419
    It would probably be a lot easier to just install VNC server on the UDOO and connect to it over the network since it has WiFi built in. This install is not straight forward now because the limited repositories in the base image, but you can enable them after you install the synaptic package manager from what i have read in the forums, i havent tried it yet personally.
    Either way, this allows you to easily use you screen, and your keyboard and mouse with no cables
  3. maurizio
    maurizio Administrator
    Jul 1, 2013
    35
    I'm trying to set up tightvncserver, I will let you know when it will work!
  4. BenL
    BenL New Member
    Sep 1, 2013
    While most modern laptops have an HDMI port, they're probably output only.
    When I get my UDOO, my plan is to use my desktop monitor which has multiple inputs and a Picture-in-Picture feature. I'll still need to use a separate keyboard.
  5. venkat1964
    Oct 16, 2013
    Thanks DracoLiasa and all,
    I did not think of the tightVNC will give it a try.
  6. DracoLlasa
    DracoLlasa UDOOer
    Oct 15, 2013
    419
  7. tibmeister
    tibmeister New Member
    Oct 20, 2013
    19
    You can use xRDP if your connecting from Windows. Another option is to use XMing on Windows and either connect to the Udoo with XDMP or use Putty and an SSH tunnel.
    The HDMI on a laptop or PC is output only. You would have to have some type of capture card to enable the input. but remoting into the GUI is the better option.
