VIN pin max current allowance
Discussion in 'General Discussion' started by Loki, Apr 16, 2015.
  1. Loki
    Loki New Member
    Apr 16, 2015
    Hello,
    I'm using the adafruit motor shield with Udoo. I'm controlling three motors which in the worst-case (when all are blocked) need a total current of roughly 2 A. The shield can be configured to power the motor from an external power supply or from the VIN pin. According to the Udoo schematics the PSU is directly connected to VIN (more or less, there are some filters).
    Is it safe to take 2 A out of VIN (provided the PSU is sufficient, of course)?
  2. TomFreudenberg
    TomFreudenberg Member
    May 12, 2014
    59
    Hi, I can not speek as an official but we are running at same condition.
    At least you should append some Elko and Resistance to secure your circuit
  3. Andrea Rovai
    Hi Loki,
    it is always safer to keep the power sources separated, thus it'd better if you power the adafruit shield by external sources. Otherwise, you have to have a power supply big enough, because the board may turns off if you use our power plug and if the motors drain too much current.
  4. nicola
    nicola Member
    Apr 23, 2014
    45
    Hi, I'm also using a motor with the udoo but it's very small and requires a small amout of current. To avoid problems I put a "big" capacitor between the driver board and the VIN of the udoo as requested by the driver board manual.
    For now everything is working fine but I'm curious about the "Elko". What is it?
    I searched but failed to find an useful solution (I dont' think you are talking about the city of Nevada).
