Plex server running on Udoo quad
Discussion in 'Linux Ubuntu' started by rocketdude, Aug 13, 2015.
  1. rocketdude
    rocketdude New Member
    Jan 10, 2014
    I've always wanted to use my Udoo as a standalone plex server (not hooked up to a monitor); leave it on all the time with 3 TB USB drive attached, no keyboard, mouse, or monitor. Finally succeeded. I can now have multiple family members watch TV or movies simultaneously, casting to chromecasts attached to TVs or tablets. Should work on udoo dual as well. Here are the steps:
    1. put a 14.04 version of ubuntu on udoo; I can't remember where I got mine. It uses kernel 3.12.8. I suspect the offical udooubuntu 2 release will be satisfactory.
    2. (optional) since this is a standalone server, I need a GUI crutch, so I installed tightvncserver and xfce4. This can take awhile due to the long list of dependencies. Now I can log into udoo with a VNC client from anywhere instantaneously. Most of the time, I use ssh. But there is the GUI if I need a crutch.
    3. Plex server install instructions at http://www.htpcguides.com/install-plex-media-server-on-raspberry-pi-2/. I chose the first option; be sure to use the jessie build.
    the hardest part was actually getting VNC working, which is really not required. The plex server just worked. My whole installation is 2 GB, so fits comfortably on a 4 GB uSD card.
  2. sirrab
    sirrab UDOOer
    Jul 26, 2014
    264
    32
    Blu-Ray quality? How many streams?
  3. rocketdude
    Jan 10, 2014
    as long as USB drive and ethernet can keep up with Blu-Ray, it should work. I have my Udoo plugged via ethernet to my router. USB drive should handle 200 Mb/s, so one would expect Blu-Ray to work.
    I don't understand streams? If I'm streaming from the network to a chromecast, then the Udoo does nothing but negotiate the connection. If you mean streaming from my USB drive, I've tested 2 HD streams simultaneously. I don't have Blu-Ray content, so can't say. As long as the content is mp4, then no transcoding occurs and it's just straight from disk to network.
    oh yah - transcoding doesn't really work - everything needs to be in a form that a chromecast (or what you use for video display) can gobble up.
  4. DracoLlasa
    DracoLlasa UDOOer
    Oct 15, 2013
    419
    thanks for this, i have been wanting to move my Plex server off my main PC for a while and have been thinking about using one of my SBC's to do it. UDOO may be a good option with its SATA support and high end performance.
    If i get a chance to try this out, i will provide feedback.
    Do you have any sort of CIFS /Samba share setup so that you can add/remove video content to your library, or do you do it another way (SCP or something)
  5. rocketdude
    Jan 10, 2014
    yes - I run a CIFS server as well as a print server from my Udoo. See https://help.ubuntu.com/lts/serverguide/samba-fileserver.html
    I have had little luck with SATA on the Udoo. Perhaps that is because I haven't often run "official" releases or because I haven't enabled the correct pins on the board. I really haven't tried very hard. Such a solution would certainly be cleaner than stringing a USB drive. Perhaps with Udoobuntu 2, SATA would just work.
