Access PWM 1-6 from A9
Discussion in 'UDOO NEO' started by maleadt, Feb 21, 2016.
  1. maleadt
    maleadt New Member
    Feb 15, 2016
    Hi all,
    I want to PWM 3 (or possibly more) pins from the A9, and according to the pinout there should be 6 PWMs available. However, following the documentation and using the device tree editor to enable the PWM feature, I can only enable PWM 2 and 5.
    How do I enable those other PWM channels?
  2. maleadt
    maleadt New Member
    Feb 15, 2016
    Also, is there a way to determine which pins /sys/.../pwmchip$X/pwm$Y correspond to?
  3. maleadt
    maleadt New Member
    Feb 15, 2016
    Looking at imx6sx-udoo-neo-externalpins.dtsi which dtweb ships, PWMs 1 to 6 are defined and available. Is there a reason the web interface only allows access to PWMs 2 and 5?
  4. waltervl
    If you edit the /opt/dtweb/public/boards/neo/board.js file you can add the other pwm pins manually. You have to take care of the pin numbering as in the mentioned pinout documentation.
    Then you can use dtweb to set them.
    I do not know why they are not yet listed in dtweb. Perhaps there are some conflicting ports? But if you give it a try we all can benefit of it :)
  5. maleadt
    maleadt New Member
    Feb 15, 2016
    I just want to make sure the pins aren't disabled for a good reason, ie. enabling them in the -dist dt will not blow up my udoo...
  6. Francesco
    Francesco Active Member
    Jun 23, 2015
    220
    110
    Yes, the good reason is that the SoC has 8 PWMs.
    6 PWMs are assigned to the Arduino core, 2 to Linux.
    If you want to use the other PWMs you must disable the M4 core, or rebuild MQX disabling the PWM capability of Arduino.
    Adding the other PWMs to the device tree (without turning off M4 - with udoom4ctl) you would expect bad behaviours (eg. kernel panics) but the hardware will not blow up.
    Andrea Rovai and waltervl like this.
  7. longhongc
    longhongc New Member
    Apr 29, 2019
    waltervl likes this.
  8. waltervl
  9. hiten
    hiten UDOOer
    Dec 9, 2019
    37
  10. waltervl
    Why are you running Android OS?
  11. hiten
    hiten UDOOer
    Dec 9, 2019
    37
    because my project is android based
    like example:- using the android os control board peripherals
  12. hiten
    hiten UDOOer
    Dec 9, 2019
    37
