GPS under Android... again
Discussion in 'Android' started by objectr, Apr 24, 2016.
Tags:
  1. objectr
    objectr Member
    May 28, 2014
    36
    I bought the Global Sat ND 105 C GPS USB Dongle for use with my Quad, but when launching the You Are Here GPS app, It won't find the position. 'Not Fixed' at Latitude, Longitude and Accuracy.
    Any Idea how to fix this issue?
    Thank you guys!
  2. idorel77
    idorel77 Member
    Jul 25, 2014
    131
  3. objectr
    objectr Member
    May 28, 2014
    36
    thank you! where exactly does the usb dongle mount?
    I copied the armeabi gps.default.so into the lib/hw folder, added the lines to the build.prop file and set the baud rate to 4800.
    Can't set the name as I only got the Vendor ID and Product ID.
  4. idorel77
    idorel77 Member
    Jul 25, 2014
    131
    Device name = port name (ex. ttyUSB0)
  5. objectr
    objectr Member
    May 28, 2014
    36
    How can I find the port name in Android?
    did it work with yours under ttyUSB0?
  6. idorel77
    idorel77 Member
    Jul 25, 2014
    131
  7. objectr
    objectr Member
    May 28, 2014
    36
    did that before, and I am only getting
    Bus 002 Device 002: ID 0424:2514
    seems like there is no driver loaded for the device?
    I will give it a shot, as I don't have a SATA drive connected your image won't work?
  8. idorel77
    idorel77 Member
    Jul 25, 2014
    131
  9. objectr
    objectr Member
    May 28, 2014
    36
    but basically I could simply connect a SATA drive and it will/should work?
  10. idorel77
    idorel77 Member
    Jul 25, 2014
    131
    yes, but the drive have to be emty , and ext4 ..
  11. mdcostas
    mdcostas New Member
    Feb 18, 2014
    14
    Hello idorel77
    I estadocon the ROM you've shared (android_4.4.2_gps_touch_sata), but the GPS does not work me, Android does not detect it. The dongle with which'm testing is the "GlobalSat nd-105c".
    Do you have any idea because it can be, or if I'm doing something wrong?
    Thank you very much.
  12. idorel77
    idorel77 Member
    Jul 25, 2014
    131
    Hi @mdcostas did you modify build.prop as your gps needs?
    you should find wich port and baud rate your gps need and then modify buld.prop.
    you can test your gps on linux , i think is easy.
  13. mdcostas
    mdcostas New Member
    Feb 18, 2014
    14
    Hi.
    Thank @idorel77
    I'm trying to modify the file with RootExplorer, riding with permissions R / W and after all I keep writing and tells me that the changes have been saved, but if I open the changes have disappeared.
    I also connect from Putty but can not find any editor with which to make changes (nano, vi, ...)
    How do I edit that file?
  14. idorel77
    idorel77 Member
    Jul 25, 2014
    131
  15. mdcostas
    mdcostas New Member
    Feb 18, 2014
    14
  16. AlexJosef
    AlexJosef New Member
    Mar 30, 2022
    How to Make a GPS App and Don't Get Lost in the Process
    There have been times when we were afraid to get lost in a strange city or had difficulties looking for a certain place, whether it be a store, restaurant, or something else. Today these problems are in the past, and we owe it all to our mobile devices. To be more specific, we should thank the geolocation feature which not only simplifies our lives in many ways but also allows us to strengthen our business, you can read more here
