Python Idle
Discussion in 'General Programming Discussion' started by joemcder, Oct 30, 2013.
  1. joemcder
    joemcder New Member
    Oct 21, 2013
    17
    Here I go again. Python works OK but I do not see Idle, the default python devel environment. (Idle, yet another poor choice of name leading to futile searches)
    Idle is actually a python library. I tried apt-get without luck. Any suggestions.
    Processing, Idle, what's next? pygame!
    There is a point to these questions. I'm interested in hybrids of video games and the physical 'Internet of things'. I'm currently working on a Lunar Lander run with stepper motors and monofilament. The front end is a Processing app on my Windows laptop connected by usb to an Arduino. Combining everything on the Udoo would be perfect- if the necessary tools are ported. Since other Arm boards have been used, I assume Udoo will work, but I am not a hardcore expert.
  2. jaeg
    jaeg Member
    Oct 22, 2013
    62
    If need be there are probably alternative options to Idle. I haven't looked for it (never used it personally).
    I'm actually installing pygame as we speak... er.. type.
  3. joemcder
    joemcder New Member
    Oct 21, 2013
    17
    Great! Let us know the results!
  4. jaeg
    jaeg Member
    Oct 22, 2013
    62
  5. mkopack
    so just install it!
    sudo apt-get install idle - this will get you idle w/ python 2.7
    or
    sudo apt-get install idle3 - will install idle 3 with python 3.2
  6. joemcder
    joemcder New Member
    Oct 21, 2013
    17
    Yes of course, but this is the reponse I get:
    ubuntu@imx6-qsdl:~$ sudo apt-get install idle
    Reading package lists... Done
    Building dependency tree
    Reading state information... Done
    Package idle is not available, but is referred to by another package.
    This may mean that the package is missing, has been obsoleted, or
    is only available from another source
    E: Package 'idle' has no installation candidate
    I get the same response for ALL attempts to use 'apt-get'. Could this be a configuration issue?
  7. mkopack
    You did "sudo apt-get update" first, right?
    That's all I did and then the commands I said above and it loaded right up. No problems at all... You've run the Ubuntu updates that were posted in the Downloads area, correct?
  8. joemcder
    joemcder New Member
    Oct 21, 2013
    17
    Nope, I forgot that sneaky old 'update' :(
    Python idle is now working :D
    Thank you for the quick help.
  9. mkopack
    Cool. Glad it's working now!
